Home made tools
Old Jan 27, 2016 | 01:43 PM
willowbilly3's Avatar
willowbilly3
Home made tools
Only the guys working on vintage stuff might appreciate this. I dragged the pictures up to show on Fordbarn so thought I'd share here. Many years ago I was short on money, needed a drill press and wanted one that turned slow to run the bigger bits, like 1". So I built this, about 50 rpm on the slow and 3 speeds of auto feed. I did extend the rest pole to the base and get a better chuck after these pictures. It works awesome and also keeps your situational awareness tuned up.
Maybe you have something birthed of necessity that you want to share pictures of.
Old Jan 27, 2016 | 02:29 PM
arctic y block's Avatar
arctic y block
Yes, I can see where situational awareness is very important.
Looks like something Gary (GB Sisson) or I would build.
Old Jan 27, 2016 | 03:04 PM
willowbilly3
And it has Ford parts. The upright is the torque tube from a 37 pickup
Old Jan 27, 2016 | 03:17 PM
willowbilly3
rear brake drum puller I made.
Old Jan 27, 2016 | 06:33 PM
michael a's Avatar
michael a
If necessity is the mother of invention, then being broke on your *** must be the grandma, grandpa and daddy of invention
Old Jan 27, 2016 | 11:42 PM
GB SISSON's Avatar
GB SISSON
I dont have a photo.., But imagine this .. Need to remove a pilot bearing fron the end of a crank. No internet, hadnt heard of using grease and a drift. Working alone late at night. OK, I take a 3/8 " carriage bolt and grind the head around the perimeter until it fits through the bearing. Now I stand this bolt in the bench vice and saw across the head and down the shank of the bolt about an inch. Next I take a random chunk of steel and hacksaw off a wedge like for a hammer handle. maybe 3/8 wide and tapering from 3/16 to zero in 1/2 ". I lightly tap the wedge into my hacksaw's kerf. Now I insert it head first into the pilot bearing. When the wedge contacts the blind hole in the crank, I continue to tap on the threaded end of the carriage bolt. The head then spreads out. Now the carriage bolt's elongated head has a hold behind the pilot bearing. A 3/8 drive socket slides over the threads, add a nut and washer to draw the pilot bearing out of the crankshaft. Took about 3 minutes to make. I worked with a guy building a 52' wooden schooner when I was 16. It was fastened with locust 'treenails', pronounced 'trunnels. No metal in the hull. The 1" hole was drilled thru the planking and clear through the heavy frames. Then sawn flush both sides. After this it was sp,lit with a chisel and an oak wedge driven in sideways to the grain. If you couldn't get to the inside for structural reasons, you'd do a 'blind trunnel'. The 1" hole was now a blind hole, not clear through. Next You slot the starting end of the trunnel on the bandsaw and set a glued wedge into the kerf . Drive the trunnel in and when the wedge contacts the bottom of the blind hole, It spreads, becoming tighter as you drive.. Now cut the outside of the trunnel flush with the planking and split and wedge. That was my inspiration for my late night split bolt pilot bearing remover. Ok, I put my ownself to sleep wiyh this diatribe..... zzzzzzzzzzzz
Old Jan 28, 2016 | 03:56 AM
willowbilly3
Interesting GB, that I learned to blind wedge from one of your neighboring islanders. I used the process in some of my log furniture but never thought of applying it to metal. Very ingenious. I've ran a tap into those pesky pilot bearings before and threaded a bolt in and did the same thing with a pipe spacer and big washer.
Old Jan 28, 2016 | 06:28 AM
Joe777's Avatar
Joe777
That drill press is a piece of industrial art! Unfortunately OSHA is deploying a swat team as we speak.
Old Jan 28, 2016 | 08:28 AM
willowbilly3
I think it's called steampunk. The switch is bad right now so osha can't turn it on and it is just "art"
Old Jan 28, 2016 | 01:50 PM
mrcman58's Avatar
mrcman58
i think rube goldberg was at it again with this drill press, i love it though. thats an original.
Old Jan 28, 2016 | 08:16 PM
49fordv8f4's Avatar
49fordv8f4
Here is a hub puller I made when I was taking the machine shop class at Twin Lakes Vocational Technical School about 40 years ago. I threaded the out side sleeve so it screws on to the body, otherwise it is very similar to the K.R. Wilson puller. The nut in the foreground screws on to the axle to keep from damaging the axle end.
Old Jan 28, 2016 | 08:23 PM
49fordv8f4's Avatar
49fordv8f4
I have a post drill identical to the one you used on your drill press. I used to have it hanging on the wall in my shop. When my boys were small, they liked to come over to the shop and drill holes in scrap steel. Now they are grown, I miss having them around!
Old Jan 28, 2016 | 10:09 PM
GB SISSON's Avatar
GB SISSON
Mark, your puller is a true masterpiece. I know all about the kids leaving home. 2 boys, 2 girls... Not a lot of careers on Orcas Island so they are all in Seattle now. Oldest 3 graduated from college, and youngest who spent the most time with dad after the deevorce works in an auto body shop down there. Funny he just called me about 20 minutes ago. Like you, I miss my kids, but am also proud they get by on their own. Excuse me for repeating this photo, but I can't help myself. OK I added some more photos. The girl in the last photo is getteing married on the island in August. There will be over 200 attending mostly his family from northern California. There are a million things I should do around the place before that but all I wanna do is work on stuck flatheads and drive some more screws into the woodie. Fortunately my kids know me and know I will never change. On the plus side we will have a dinner the night before where we roast a 120 lb pig in the old diesel tank on a 35 ford axle.
Old Jan 30, 2016 | 04:38 PM
1952henry's Avatar
1952henry
I have, or will when I pick it up, a champion blower and forge No. 203 post drill. It is a big one. It has two speeds and a flat belt pulley complete with idler. Was used with the power shafts in blacksmith shops. I bought a model a transmission for $15 recently to give it 6 speeds. When I get it set up I plan to run it off an old gas engine. I saw a picture once of a fellow who used an electric motor to power one through a model a transmission.
Speaking of model a transmissions, I ended up making a tool to remove lever spring. After seeing the spring I realise all the caution that is expressed when dealing with one
Old Jan 30, 2016 | 06:21 PM
willowbilly3
If you run the gas engine you will have to have a way to control the blower. You can't just turn it on. Maybe some kind of stomp pedal to a belt tensioner. With the electric motor you use a rheostat pedal.
