Door Ajar/Interior light switch
Old Jan 25, 2016 | 09:49 AM
Absolute's Avatar
Absolute
I have an odd issue. When I close my drivers door the door ajar light on the dash won't go out, and it chimes warning me its open, and my interior and bed light won't got out. I think the ajar switch may need cleaning and is stuck up. Found my wire diagram, but I can't find the switch. I thought it would have a button sticking out that the door pushed when closed, but no. Can anyone tell me were the switch is so I can service it or disconnect it if broken so my batteries don't go dead???
Old Jan 25, 2016 | 10:54 AM
Pikachu's Avatar
Pikachu
It's on the underside of the lock mechanism inside the door. Some people have had success spraying lubricant down through the latch and somehow managing to get enough of it into the switch.
Old Jan 25, 2016 | 11:06 AM
Absolute's Avatar
Absolute
Oh, its in there. Ok, no problem pulling the panel to fix it. Thanks. So I assume the latch closing is what trips it then? Cause the latch is working correct. Just the switch I intermittent.
Old Jan 25, 2016 | 11:40 AM
Pikachu's Avatar
Pikachu
Yes, it's a pin-type switch that the latch mechanism actuates. I've never had any luck spraying it through the latch mechanism. I've had to pull the whole mechanism out, remove the switch and lube it. I hit it with contact cleaner while working the pin in and out, then repeat with oil. Did mine about 2.5 years ago and haven't had a repeat failure.
Old Jan 25, 2016 | 04:20 PM
Absolute's Avatar
Absolute
Yup, that was it. Lubed and cleaned. Lights out! Thanks.
finnur
1997 - 2003 F150
Feb 1, 2005 09:00 AM
Boss50
1997 - 2003 F150
Jan 31, 2005 08:21 PM
dumpsterdan
1997 - 2003 F150
Jan 27, 2004 11:09 AM
Bowcop
Dec 10, 2003 07:56 AM
