Sponsored by: Auxito
Courtesy Light Door Switch
Old Jan 27, 2004 | 08:23 AM
dumpsterdan's Avatar
dumpsterdan
Can someone tell me where the switch is located that turns the interior lights on when I open the drivers side door. The passenger side works fine, but not the drivers door.
Old Jan 27, 2004 | 11:05 AM
Racerguy's Avatar
Racerguy
The switch is right inside the door latch.
Quite often you can get the switch working again by spraying lots of WD40 into the latch and open and close the door a few times. The WD40 cleans out the gunk that's built up in the latch and switch.
Dont use a spray grease instead of WD40 as they tend to gum up in the latches.
Old Jan 27, 2004 | 11:09 AM
dumpsterdan
thanks of the tip, Racerguy!
