Sponsored by: Real Truck
Door switch ?
Old Nov 26, 2003 | 10:26 AM
Bowcop's Avatar
Bowcop
Door switch ?
Where in the heck is it!!?? I cant find it for the life of me. I have an 01 SD. I am talking about the door switch that turns on the dome light.
Old Nov 26, 2003 | 10:33 AM
To D Lake's Avatar
To D Lake
It's built into the latch.
Old Nov 26, 2003 | 11:05 AM
Bowcop's Avatar
Bowcop
THANKS!!!! This has been driving me NUTS!!!
Old Nov 26, 2003 | 12:19 PM
nafzimo's Avatar
nafzimo
They stick. Soak it with WD40.
Old Dec 8, 2003 | 06:34 PM
Hammer Hog's Avatar
Hammer Hog
Which latch? Inside or outside? I'm about ready for the BFH!!!
My Door-a-Jar light keeps coming on while driving. Sometimes it goes on and off within seconds of each other. At night if it's on...the dome lite comes on when I come to a complete stop
Old Dec 8, 2003 | 09:46 PM
nafzimo's Avatar
nafzimo
Originally posted by Hammer Hog
Which latch? Inside or outside? ...
Um... open the door and spray it into the latch (inside the door)... where it would grab the nader bolt like thing... if it were closed.
Old Dec 9, 2003 | 08:33 PM
byronjod's Avatar
byronjod
My 2000 SD Crew Cab is doing the same thing. Just started today. I came to this site to find a similiar problem and, "Wow"
it was right there.
Old Dec 9, 2003 | 08:51 PM
Hammer Hog's Avatar
Hammer Hog
I tried spraying the latch and now it seems worse than ever
Now what?
Old Dec 10, 2003 | 05:13 AM
klp's Avatar
klp
Hammer, open the door and spray the ****e out of the latch mechanism. Open and close the door 50 times. Then spray it again. You know you have done it right when WD leaks down the outside of your door.
I just had the same problem on my 99, no worries now. I am sure the senior guys here are pretty sick of this type of post, so I figured I could chime in. Good luck. KP
Old Dec 10, 2003 | 07:26 AM
rshober's Avatar
rshober
Do the door locks cycle at all when your moving...like they're trying to lock when they're already locked? The vehicle security module (VSM) went out on my truck, and it caused all kinds of weird stuff to happen-including things similiar to what you're experiencing.
Bert
Old Dec 10, 2003 | 07:56 AM
RedTaurus94's Avatar
RedTaurus94
My dome light will not come on when the driver's door is opened. It works with the other 3 doors just fine, but not the one that matters most. I have sprayed WD-40 in the latch until it dripped onto the ground from the bottom of the door, but still no dome light. I will admit that I didn't open and close the door 50 right then, however. How much of a PITA is it to install a new switch?
