I looked up pictures of Y block water pumps and there seems to be a couple of styles, one for trucks apparently has a heavy mount with two holes off to the side, the standard type does not have anywhere that I could see where your plug would go...unless it is the female pipe threads for the heater hose nipples. And 5/8 hose usually uses a 3/8 pipe thread. Do you have a picture of the location?
