Cannot get into 4WD Low
Old Jan 24, 2016 | 08:01 PM
japple157's Avatar
japple157
Question Cannot get into 4WD Low
I've got a 1989 F-150 XLT Lariat. I can get the 4WD shifter into high by just pulling up on it, but refuses to go down into low. Pattern shows to move shifter to the left and then back, but it will not budge. Do not want to try to force anything. Truck has got a 3" body lift on it. If anyone can lend some advice to what my problem may be it would be much appreciated. Thank you.
Old Jan 24, 2016 | 08:52 PM
Big_Al59's Avatar
Big_Al59
Usually have to push down on lever while going into low. Also be in neutral, park etc.
Old Jan 24, 2016 | 09:00 PM
Fastback460's Avatar
Fastback460
The transmission has to be in neutral to shift into 4Lo
And like Big_AL said, you need to push down on the lever while pulling back.
Old Jan 24, 2016 | 11:07 PM
whisler's Avatar
whisler
On my '89, there is a detent that keeps you out of 4 LO. The shift lever pivots slightly to the left and is spring loaded toward the passenger side. You need to push the shift lever toward the drivers side against the spring to clear the detent and then pull back into 4LO. If yours is any thing like mine was, the the pivot point is seized up and won't move left. You will probably have to remove the shifter and soak it in Kroil to free it up.
Old Jan 25, 2016 | 06:54 AM
tjc transport's Avatar
tjc transport
i ain't rite
there were two transfer cases used in 89, so both answers are correct. look at the shift pattern. it will either show push to left and pull back, or push down and pull back. either way, the trans needs to be in neutral to shift into 4 low.
and if it still will not move, it is most likely locked up from lack of use and will need to be removed, taken apart, and cleaned.
Old Jan 25, 2016 | 07:36 AM
chrismd188's Avatar
chrismd188
Mine has a 3 inch body lift on it and it shifts perfectly,I would crawl under it an check the linkage make sure its not rusted,you might have to soak it with pb blast or kroil
Old Jan 25, 2016 | 08:35 AM
Conanski's Avatar
Conanski
Both my '89 and '90 trucks had the pull to the left shift pattern for 4 low and both mechanisms were totally seized when I bought the trucks. Do not force it or you will break the linkage, you're going to have to crawl under there and remove the whole linkage... dismantle and lube.
Old Jan 26, 2016 | 01:05 PM
japple157's Avatar
japple157
Yeah i took a look underneath. I do believe the problem is its seized up from not being used in so long like you said. Gives me a small project to do over the weekend. Thanks for the help guys.
Old Jan 26, 2016 | 02:54 PM
tjc transport
i ain't rite
i only had luck loosening one on truck. all the rest i had to remove and take apart to properly clean and lubricate.
massdld
Sep 12, 2009 12:30 PM
sniffer1dog
1997 - 2003 F150
Nov 15, 2008 07:10 AM
RotGrubestier44
Sep 5, 2006 09:37 PM
ret72
Nov 14, 2003 09:48 PM
