front wheel location
Old Jan 24, 2016 | 04:18 PM
Marten's Avatar
Marten
Can someone tell me what the dimensions should be for front wheel placement. The challenge is there seems to be 1" difference at the bottom of my front fenders from one side to the other. 34 1/2" on one side and 33 1/2" on the other. Could be that one is bent. Not sure whether to measure at the centre of the wheel or the bottom of the fender well opening. Right now my shop is very tight for space and I cannot stand back and just look at it. Rolling it outside might be possible but could be a challenge as well and my wheels are 1/2" plywood only. The motor is in so it is a little heavy.
Thanks
Marten
Old Jan 24, 2016 | 04:31 PM
52 Merc's Avatar
52 Merc
It would be helpful to know what you're working on...
Old Jan 24, 2016 | 06:25 PM
drptop70ss's Avatar
drptop70ss
Plywood wheels?
What exactly are you trying to measure?
Old Jan 24, 2016 | 09:07 PM
Marten's Avatar
Marten
I have a '53 pick up. What I am trying to do is see if my front wheels are centered in the fender opening. I know that the original wheels are set back a bit to far. The previous owner installed a new cross member from Flat Out Engineering but at this point I am not sure it is in correctly front to back.
Plywood wheels, I made a set of wheels out of plywood to allow me to move the frame around. It saves me buying wheels and tires right now as it will be a couple of years before this truck is on the road. the wheels are cut to the same size as the final diameter of the tires. Picture gives you an idea of what I did. Truck is farther along then that now.
Old Jan 24, 2016 | 09:28 PM
Oldb's Avatar
Oldb
So I think you are talking about having the front wheel centered in the wheel opening? If so and you have a full inch difference side to side that is a concern. I would start measuring diagonally to make sure the previous owner set the chassis up correctly. I realize in a tight shop that could be tough but you need to be sure the chassis is correct. Best of luck.
B
Old Jan 24, 2016 | 09:32 PM
drptop70ss's Avatar
drptop70ss
If the rear axle is straight and square to the frame measure from the rear axle center line on each side to the front lower ball joint on each side and you should have the same measurement if the IFS crossmember is straight. You cannot measure to the front wheel CL because if the spindle is turned the measurement is NG. Lower ball joint is a common fixed point on each side, and is normally very close to the actual front wheel CL.
As far as what your measurement should be the 53 up guys will chime in, I think they offset the front wheels about 1 1/2" forward to center the wheel, but I dont know what the wheelbase should be off the top of my head.
EDIT I see you have a corvette rear so not sure you can assume it is straight. Make measurements from factory locations on each side of the frame. Either way that is some serious anti-dive angle on those front upper control arms, hopefully the crossmember was put in place to be correct at the final driving frame rake. Looks like a no limit kit?
Old Jan 25, 2016 | 04:21 AM
Justboy's Avatar
Justboy
Excellent idea with the plywood - wheels take up a lot of space when they're off. As already mentioned you need to check your frame is straight and square before placing the front wheels.
Midfifty or similar have diagrams to show the location of the front wheels. I think the distance shown here is stock and not the plus (1.25-1.75)" you probably need.
Instructions - Mid Fifty F-100 Parts
Old Jan 25, 2016 | 05:24 AM
Marten's Avatar
Marten
Hi guys
Misunderstanding. The frame work is square. It is the fender wheel opening itself that is different from one side to the other.
Old Jan 25, 2016 | 07:07 AM
drptop70ss's Avatar
drptop70ss
radiator support crooked? Cab crooked? Not sure what the tolerances are on fenders, if everything checks out square I would start measuring and comparing one fender to the other.
Old Jan 25, 2016 | 07:32 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
I'm far from insightful on this, but have read here that alignment of front sheet metal on 53-56s can be more art than science. My reason for commenting, I have a copy of the '53 Body Builders Layout Book that gives measurements that are insanely detailed. It can't be scanned, too big and faint, but I'll mail a hard copy if you pm me a mailing address. Stu
Old Jan 25, 2016 | 08:08 AM
AXracer's Avatar
AXracer
It is not unusual for fenders to be different sizes, different year replacement, collision repair replacement, etc. Early replacements even OEM were made from well used and reworked dies, aftermarket repop dies or imported back from Ford stampings from other countries (Ford would ship their previous model dies to 2nd and 3rd world countries where our older models were made and sold as their latest model year. An easy way to determine where the new crossmember was installed (stock or forward) is to simply measure the wheelbase on your frame. Stock F100 location would give 110" wb, relocated will measure 110 + 1.25 to 1.5".
xumeng12
Nov 22, 2024 04:39 AM
00Dave
Oct 25, 2018 10:27 AM
Nitro1168
Apr 7, 2016 04:17 PM
bronkntrukholik
2009 - 2014 F150
Jan 20, 2013 04:43 PM
holland501
Aug 21, 2004 12:16 AM
