(Front end noise) Turned Big Fix
#136
That sucks nathan. Anything can work but the hard part is how much work it is to make it fit. I wouldn't be surprised if Brad has some insight on the matter. Plus you get a stronger chassis too. Last year I saw a rolling chassis at a mom and pop salvage yard on the way to cultas lake. I'll see if it's still there
#137
All stories that start with, 'I know a guy.....' make me skeptical.
How ever that being said I expect skepticism on this one.
I know a guy that says 300 cad to fix the frame. I sent photos before getting a price. I asked if he would do the other side too. He said no, I said how about another 300. He said heck yes see you Tuesday next week.
So I am sure there is a lot to be worried about however; it's cracked and I need it fixed.
Problem is when the bed is off it is going to be hard not to go 'guns and ammo' on this sucker.
Bare minimum is spring mounts and brake lines right? Oh and cleaning the heck out of it then prime and paint.......
Oh crap...
Oh crap...
#138
#139
#140
So the process has started. I am helping out by making as many parts as I can.
The plan is to get some soft ride 5 leaf springs and reinstall the air bags for the camper. The springs will have 4" of lift to eliminate some of the blocks. I may install traction bars at some point.
The air bags are off and I plan to make the plate to reinforce the frame. How big should I make it? Should I remove the shock mounts sway bar mounts and overload spring mounts and run it through? Should it go to the spring mounts? I am thinking of using 3/16 mild steel to make the plate. I am hoping to learn something here.
#141
#142
#143
#144
First step is done. Next grind and weld inside frame. Finally plate and weld.
While it was apart I replaced all the rear brake components. Need to make one cable guide for parking brake cable. The wheels will be off again soon for the final frame repairs which will involve removing the shock mounts and a few other things.
I need to move my tail pipe back and toward the center of the truck. Not sure how much of the 38gal tank will be pounded in.
Thanks for reading!
Is my ignition switch my dash power problem?
#145
I replaced the ignition switch and the problem persists. The maxi fuses have a bit of rainbow coloring on them. I swapped a few around and the condition did not change.
I am thinking of running a jumper cable from the ground by the parking brake to the negative terminal on the battery.
I am grasping at straws. I did notice the relays at the power distribution box get quite warm.
#146
#147
#148
Yesterday I had a few minutes before starting work so I tested power at the radio connector, all good. Then I tested the grounds. OK but not that great. So tonight I had a few minutes and pulled the passenger kick panel. I didn't have my phone to take a photo. There was paint and a ground strap, but no metal. As soon as I touched it there was a puff of rust and dust. I got the wires cleaned and reattached further up. Voila radio works and gauges work.
So I have learned that the dash grounds to both sides of the truck. My cab is really poor shape. Bummer.
