Leaking coolant (1946 239)
Old Jan 23, 2016 | 07:22 PM
c249a's Avatar
c249a
Hi
It's finally done! My engine is back in service!
After being rebuild i've reassemble everything and start it!
It start on second attempt! It ran for 30 sec and I stop everything to make sure everything was ok.
The only problem is that one of the head bolt is leaking a little bit of coolant.
Only small drips...
I'll check back the torque on each bolt tomorrow.
But do you think this is normal?
Any advice or trick?
Thanks!
Old Jan 23, 2016 | 07:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Did you use a sealant on the studs? Pretty common issue with the 59-series engines. It may just stop on its own.
Old Jan 23, 2016 | 07:33 PM
3twinridges's Avatar
3twinridges
Ross, I think I have asked you this before but what sealant do you recommend on the bolt threads?
Old Jan 23, 2016 | 08:44 PM
c249a's Avatar
c249a
I don't know i'll contact the shop who rebuild the engine!
thanks
Old Jan 23, 2016 | 09:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On my 8BA (which uses bolts, not studs) I use anti-seize. The guys with stud engines usually recommend either Permatex #2 (non-hardening) or GM Part number 012346004, Teflon® Pipe Sealant. 50 cc's cost $18!! But its supposed to be the best.
Diesel cat
Feb 1, 2012 07:23 AM
Benny2002
20
May 31, 2008 07:14 AM
lugnutt
Modular V10 (6.8l)
Dec 24, 2007 11:24 PM
JDMAC
Sep 29, 2004 07:58 AM
gt bronco
Dec 8, 2002 06:35 PM
