7.3 e350
Old Jan 23, 2016 | 09:19 AM
bakertunnel's Avatar
bakertunnel
7.3 e350
Stock air box has broken clips so I need to replace the top have. Just wandering if there is any aftermarket options out there? Doesn't look like the 6637 would fit?
Old Jan 23, 2016 | 09:44 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Is the stock air box on the E350 the same as on the pickups? If so, then the 6637 should fit. Having said that, the 6637 is noisier than other intake air filters. And you pretty much sit on top of the motor in a van, would you want the extra noise in there with you? If the factory air box is the same as the pickup trucks, would an AIS work?
Old Jan 23, 2016 | 09:50 AM
bakertunnel
E350 is totally different then the f250 or f350 setup.
Old Jan 23, 2016 | 12:17 PM
SMT_FORD's Avatar
SMT_FORD
works on either or.
jimandnena
21
Mar 12, 2020 09:37 PM
goatsniffer
13
Nov 7, 2008 07:23 AM
stroker870
Nov 1, 2008 12:49 PM
josephfogg
Aug 24, 2005 09:11 AM
