Popping front end
Popping front end
The list of things i have replaced/done:
Thanks in advance
- All ball joints
- radius arm bushings
- Pro aligned
- lug nuts
Thanks in advance
You might be suffering from rivet popping, either the engine cross member or the transmission cross member.
You sound confident its emanating from the front of the truck so I'd check this out,
http://www.supermotors.net/registry/media/520094
Posting the specifics of your truck might prove beneficial too. Such as model and year, engine and trans combination 2 or 4 wheel etc etc.
Took me a few minutes to find the linked to page I wanted, you must have posted it while I was searching.
Odd I your sig isn't included in your first post.
I just replaced both front rotors, wheel bearings, and seals. I hypothesized that the bearings were possibly worn and the rotors were either cracked or warped.
Some of the symptoms were:
Out with the old, in with the new. Some cheap rotors from O'Rielly.
- The old wheel bearings were shot and were coming apart. The grease was black with metal shaving and dust.
- Every time I would press on the brakes while I was at a complete stop, the rotors would creak-and-pop. Also every time I made a sharp turn regardless of the speed.
- The front end would pop/bind when I would turn the wheel full lock-to-lock.
DaveWW00
11-21-2004 01:01 PM
kev100
06-17-2003 01:28 PM
d hendrick
05-28-2003 10:23 AM
