Compared to my V10 Excursion ( 8 MPG personal license plate ) which I drove 30 miles daily before getting my 6.2 F-150, the 6.2 is like a Prius!! I hit almost exactly my EPA numbers listed on my window sticker of 12 city / 13 mixed / 16 Highway
Well, when I drive somewhere, Ill put 100 + miles on whatever I drive. Its nothing for me to drive 500+ miles in a week. I average 500 miles a week. can be more. so with the miles I drive, fuel economy is a concern. But I will say that my 6.2 does very well on gas . my 2001 with the 5.4 does no better. only time it does is when I drive it empty on a road trip.......and the 5.4 truck has 3.55s and the 6.2 has 3.73s.
I hear ya, I've settled down on miles to about 300 every 10 days or so with my daily commute but sometimes weekend trips will rack it up higher.
Back when gas was $4.40/gallon and I was driving the 6.8 Excursion daily I was putting $160-$180 in every 8-10 days, combined with my old 5.4 Expedition which was getting the same amount of miles weekly I spent $800-900 a month in fuel for awhile.
Amen to that. I came from a V10 as well. I was ecstatic when I calculated my MPG's on my 6.2 for the the first time and it was double digits!
My work truck is a 2013 5.0 F150 and I typically only get about 1 to 1.5 mpg more in that than my 6.2.
I have to admit the 6.2L is in a class of its own at the top of the Ford Engine Pyramid. It wasn't an option for me but if you can find one.....jump on it.
Perhaps for top-end performance, but certainly not low-end grunt. I've pulled with a 6.2L in a Super Duty and it was pretty undewhelming compared to the low-end grunt of my previous V10. The EcoBoost has significantly more low-end torque than the 6.2L does, which means the 6.2 will be shifting around more when pulling. Nothing at all wrong with that, but some folks don't like it.
Likewise the old 5.4L makes a bit more low-end torque than the newer 5.0L engine. The only option that I wouldn't choose would be the 4.6L 2V engine, and that's mainly because it's in front of the dinosaur-spec 4R75E transmission.
When the 6.2 was offered in the F150, it was Ford's premium engine in the line up over the 3.5, 5.0, 3.7. While I do agree the ecoboost makes it's torque sooner on the curve than the 6.2, it's still less than the 6.2. In fact the 6.2 makes almost 30 ft lbs more torque than the eco, just at a higher rpm.
You can't compare the 6.2 in the Superduty to the 6.2 in the F150. The Superduty 6.2 is tuned down and a much heavier truck. I agree, the 6.2 in the Superduty is underwhelming compared to the V10.
I've read somewhere on this forum that the 6.2 make the same power in both trucks. There is a different rating for the F250. Probably the weight and size of the F250 makes it feel slower. I have no complaints with the 6.2 in my F250. My EcoBoost F150 is more fun to drive.
I did a lot of towing with my EB. About 40K of the 80K miles on it were towing. That engine is a fantastic towing engine.
The Superduty 6.2 makes 385 hp and 405 lb. ft. of torque.
The F150 6.2 makes 411 hp and 434 lb. ft. of torque.
434 - 420 = 14 ft-lbs difference, not 30.
According to Mike Harrison, the chief engineer for the 6.2L engine, the Super Duty engine isn't turned down any:
Originally Posted by mike-v8ford
I can only compare the 6.2L in SD to the 6.2L in the Raptor. It is essentially the same engine other than the cams (slightly less overlap for a smoother idle).
Obviously the F150 is a little quicker due to less weight, and rides a little better.
There is some speculation that it's rated on premium fuel for the F150 and 87-octane in the Super Duty.
Here's a link to the Q&A thread from six years ago:
Ha! Good catch and you are correct. I was calculating the difference between the SD and F150.
I've seen that q and a as well. It was early on before everything went into production and hard numbers were out. The hp tq numbers I got were from Ford's website.
Don't get me wrong, I think the 6.2L is a great engine. I think it's more likely to see super high miles while living a hard life, and the high-end power is really amazing. I'd love to get the chance to compare it directly with an EB truck with a trailer in tow, but they're rare enough that it would be tough to put that together.
I drove 70 miles to check out a used 6.2L Super Duty. Wasn't in as good of shape as I wanted, and I ended up being offered a deal I couldn't refuse on my '15 F150.
I really like my 6.2. it has ALOT more power than the 5.4. from what Ive read the 3.5 ecoboost does have more torque on the low end, and that is what you want for trailer towing. But maybe Im just too old fashioned......I just prefer a NA V8. but Im slowly opening my mind to the ecoboost. Ive talked to people about theirs and they are happy with them.
I almost went EB but then I thought down the road 150k miles when all the extra parts on a twin turbo system start to have issues, i figured the 5.0 would have less issues. More power= more problems!
