02 sensor replacement
Old Jan 19, 2016 | 12:12 PM
Headviking's Avatar
Headviking
Just the other day I had a "longer then usual" crank to start issue. This afternoon I got a CEL light (code P0430).
edit: brain fart
So should I replace all my 02 sensors? Or just the bank 2 aft 02 sensor?
I have 250,000klm (150,000 miles).
No drive ability issues.
Old Jan 19, 2016 | 12:17 PM
NotURMailman's Avatar
NotURMailman
You say you have a 2007 with a 6.0 PSD that has O2 sensors?
I seriously doubt that...
Old Jan 19, 2016 | 12:23 PM
Headviking's Avatar
Headviking
Whats the code representing then? P0430.
What sensors?
WatsonR's Avatar
WatsonR
My eyes can't focus... they keep bobbing up and down
that's an O2 sensor.... generic code for low flow. Probably a Catalytic converter sensor, maybe plugged? Try disconnecting and re-connecting the wire... if it's there. May be time for a new CAT.
Best guess...
DSMMH's Avatar
DSMMH
0403 is an EGR code.
Ed
Old Jan 19, 2016 | 12:30 PM
Headviking's Avatar
Headviking
Ed
Not 0403 but 0430.
Old Jan 19, 2016 | 12:54 PM
Headviking's Avatar
Headviking
In the code list I found this for my code.
P0430 - Catalyst System Low Efficiency Bank 2
What do I check?
Bit of a panic, my government drive clean test for my truck is due in a couple weeks.
Any suggestions would help. Just watch the bouncing ...................
Old Jan 19, 2016 | 01:05 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Clear the code and see if it pops again. Are you sure you're not lesdysxicaly transposing the EGR code?
Old Jan 19, 2016 | 01:30 PM
NotURMailman
How did you pull the code? With your Scangauge?
Old Jan 19, 2016 | 03:25 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Maybe with a potato?
Old Jan 19, 2016 | 05:42 PM
Per4mance's Avatar
Per4mance
No O2 sensors in a PSD
Old Jan 19, 2016 | 07:14 PM
Headviking's Avatar
Headviking
Yes with the Scangauge.
I did clear the code and I'll see if it comes back. If it does, I'll need to replace the _______.
I doubt the cat needs to be replaced. With only 250000 klm (150000 miles). they should last longer then that.
Old Jan 19, 2016 | 08:46 PM
Headviking's Avatar
Headviking
So what does it cost to replace the "Catalytic monitor sensor" specifically Bank 2? Not even thinking about replacing the CAT.
Anyone here have a CAT for sale?
Old Jan 19, 2016 | 09:41 PM
KDAVID1's Avatar
KDAVID1
No such thing on a 6.0. Only emissions you have is egr valve and catalytic converter. Might consider the ebp sensor as emissions ( using the term loosely)
Old Jan 19, 2016 | 10:07 PM
Headviking's Avatar
Headviking
The code I got was P0430 - Catalyst System Efficiency Below Threshold. Bank 2.
Are there any sensors before and after the cat?
