Another MAF swap question
Old Jan 20, 2016 | 06:04 PM
RIKIL's Avatar
RIKIL
Originally Posted by Lead Head
There are no AHACB (WAY1, HOG0, HOG1, etc..) strategies available for TunerPro. The only one around is SailorBob's strategy for Binary Editor.
Yeah, using TunerPro with an ODBI strategy will be cheapest.
Old Jan 20, 2016 | 07:01 PM
Lead Head's Avatar
Lead Head
No. There are no TunerPro strategies available capable of tuning a MAF E4OD Computer.
Old Jan 20, 2016 | 07:32 PM
DeathRangerofDeath's Avatar
DeathRangerofDeath
Is it a strategy or a definition? I thought the strategy was the coding in the computer/ecu, and the definition is the file used to decode or make sense of all the gibberish the ecu spits out. Am I mixing terms up?
Old Jan 21, 2016 | 09:34 AM
RIKIL's Avatar
RIKIL
Yeah, that is where it starts to get pricy. I completely took the E4OD out of the equation and use a trans controller. So I can basically use an ECU for a manual or auto trans because the trans is controlled completely separately
Old Jan 21, 2016 | 10:03 AM
Lead Head's Avatar
Lead Head
Sorry, definition file. The definition is matched to the strategy.
Old Jan 21, 2016 | 10:10 AM
GuitarJesus's Avatar
GuitarJesus
The WAY1 will not run the 460 properly as is. The load tables will be all off, and the SEFI injector firing order is wrong.
Firing order off? 1-5-4-2-6-3-7-8. That's the 5.0 and 460 FO if I'm not mistaken.
Old Jan 21, 2016 | 10:18 AM
GuitarJesus
Originally Posted by Conanski
I'm pretty sure there have been members here with OBD1 MAF 460 trucks, I remember everyone being surprised that it existed. But even if that is true those trucks were rare so I don't know what luck one would have finding a PCM.
Every one I've seen is a modified truck. Never have seen a OBD 1 stock MAF truck. I've called a local Ford parts guy who can find me any part number and he was stumped. I have however, living in Southern California, seen a ton of 96-97 OBD2 F350's.
Old Jan 21, 2016 | 01:00 PM
Lead Head's Avatar
Lead Head
MAF 5.0s use the HO firing order.
Old Jan 21, 2016 | 01:48 PM
DeathRangerofDeath
From what I gathered they just have you repin the harness to account for the firing order difference. Which from I have been reading, isn't really the best way to go about it. Although with 1 O2 sensor it probably doesn't matter much.
Ron Pauly
Computer Chips & Tuners
Jun 6, 2018 11:56 PM
Hounddog460
Mar 4, 2018 12:19 AM
MTRN92
Oct 16, 2013 05:05 PM
Fordman96
Oct 14, 2011 05:28 AM
Fordzzzz77
Jul 29, 2002 05:42 AM
