Catalytic Converter replacement
Old Jan 18, 2016 | 06:00 PM
kurtsilverstein's Avatar
kurtsilverstein
2005, 6.8, 316k and it's time. I need to replace my CC. What are my options and costs? Love my truck
Old Jan 18, 2016 | 09:26 PM
wpnaes's Avatar
wpnaes
Haven't needed to replace many of those (based on threads here) on the 6.8l. Let us know how your estimates turn out.
Old Jan 18, 2016 | 09:43 PM
pirate4x4_camo's Avatar
pirate4x4_camo
About $300 from rockauto
Old Jan 18, 2016 | 10:59 PM
DidieX's Avatar
DidieX
Replaced min at ~205k miles. Went with generic aftermarket at a local Meineke. Cut out the old one and welded in the aftermarket with a short length of pipe (old one was longer). Think I paid $400. The old one was clogged up real bad and makeing all kinds of noises. Preformance was terrible too. No check engine light though. One thing I would think about, check you manifolds and studs. If they need work too then do it all at one shot. Unless you plan on doing it yourself at your own pace.....
Good luck and let us know how it turns out!
Edit: I have a 6.8
Old Jan 19, 2016 | 07:51 AM
LivingLarge's Avatar
LivingLarge
The rockauto price seems decent...
Old Jan 19, 2016 | 08:55 AM
Apocalypse's Avatar
Apocalypse
Agree. Go with what the vehicle expects to be there and the emission system is tuned for. It will run better with the appropriate items in place
Old Jan 19, 2016 | 11:20 AM
kurtsilverstein
In NYS thanks to Gov. Cuomo we must get OEM CC's. So, being that my CC is still working (the reason for the replacement is that there was rust at the front of the CC and it seep rated into 2) I had a friend weld it back into place and at a fraction of the suspected high cost of replacement. So I will keep welding until the CC fails. And therefore I still do not know the cost to replace. And I hope I never find out, lol.
Thanks for the advice!
Old Jan 19, 2016 | 10:30 PM
DidieX's Avatar
DidieX
In NYS, if the vehicle is CARB compliant then you must use a CARB compliant replacement converter. Problem is, most of the aftermarket converters are not CARB compliant, and the ones that are cost a pretty penny. OEM is expensive too. My Ex is not CARB compliant so I didn't have a problem. But my Toyota Sequoia is. I had problems getting replacements when they stole the cats off it, they just crawled under and sawed em off.
02f-2504X4
Jul 17, 2017 09:45 AM
Hunt89
Jun 13, 2012 08:15 AM
welbo97
Jan 16, 2008 10:43 AM
SShank42
Bronco II
Oct 16, 2007 05:49 PM
