Sponsored by: Real Truck
Sync only has one usb
Old Jan 18, 2016 | 02:20 PM
Myyke's Avatar
Myyke
I was just looking to hook up my 2nd usb on my new 2016 SD, but when i looked on the box there is only one usb on the board. My 2014 had 2 usb ports. Do i need to upgrade module or can i somehow split single usb into 2?
Old Jan 18, 2016 | 03:35 PM
Larietpsd's Avatar
Larietpsd
My 15 has 2 in the dash box
Old Jan 18, 2016 | 03:37 PM
Myyke's Avatar
Myyke
My '14 did as well, did some checking and usb is actually missing on the board, not sure why there isn't a second one on my '16
Old Jan 24, 2016 | 10:33 PM
IamScary's Avatar
IamScary
Design change id guess. Try buying a splitter.
Old Feb 1, 2016 | 12:11 PM
Steeda's Avatar
Steeda
Not sure how it works with Sync, but by design according to the IEEE Specs a USB port can handle up to 5024 devices on a single port with a splitter. That is the USB standard, no idea if Sync will support that. Could always try.
Old Feb 1, 2016 | 01:10 PM
BCM's Avatar
BCM
Sync can't support multiple devices on one port. Each device needs its own port.
Old Feb 1, 2016 | 01:35 PM
davester250's Avatar
davester250
Um, I believe it's 1024 USB devices, using powered hubs. You cannot get enough power from a regular USB2 port to do anything like this.
You MAY be able to buy a 'splitter' cable for this specific circumstance, which is likely to just plug in and charge two usb devices at once [and maybe even support SYNC with one of them], but the two devices will charge slower if just one device was attached at a time.
Old Feb 1, 2016 | 02:14 PM
auburngrad's Avatar
auburngrad
Interesting. I only have one also. Never knew others had 2. This is in a '15
Old Feb 1, 2016 | 05:03 PM
Frantz's Avatar
Frantz
XL and XLT trucks with SYNC have one. Lariat and up get more. As per 2016 order guide. Not sure if you downgraded or not.
Old Feb 1, 2016 | 05:39 PM
Just Strokin's Avatar
Just Strokin
Are you looking at the actual sync module (APIM) on the passenger side of the truck on the A pillar behind the glove box? Or is the one port you are seeing in the compartment in the center of the dash?
Old Feb 2, 2016 | 06:28 PM
Myyke's Avatar
Myyke
Actually looking at the sync module behind glove box. there's a hole for 2nd usb in the plastic , but nothing on the board itself.
Old Feb 2, 2016 | 07:42 PM
Just Strokin
I wonder if you can get an older sync module and it work.
you might email the 4dtech folks and ask them
Old Feb 2, 2016 | 08:11 PM
Myyke's Avatar
Myyke
Was thinking of going to salvage yard and see if i can find one.
Old Feb 2, 2016 | 08:48 PM
Just Strokin
Have you tried PM'ing the Ford IVT Team? They handle the Sync questions on here
https://www.ford-trucks.com/forums/p...newpm&u=710543
Old Feb 3, 2016 | 10:54 AM
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Thanks for the mention, Larry. This one is out of our scope as USB II is designed for dealership use only.
Whitney
