Backpressure?
Old Jan 17, 2016 | 09:06 PM
IHdieselfan's Avatar
IHdieselfan
Backpressure?
I have a 90 150 with 5.0l. I removed the smog pump and associated parts properly. Driven it 8 to 10, 000 miles. Now starting to have exhaust leaks. Would removing smog cause catalytic converters to stop up and cause extra backpressure.
Old Jan 18, 2016 | 12:14 AM
TexasGuy001's Avatar
TexasGuy001
I believe the stock cats actually need the smog pump to operate properly. Its my understsnding that the newer ones generally don't need the pump.
Old Jan 18, 2016 | 12:42 AM
BruteFord's Avatar
BruteFord
Please delete
Old Jan 18, 2016 | 10:18 AM
IHdieselfan
Motor runs great, I installed the spacer plate on the idle air control valve, the best 40 bucks I've spent on it. I found the leak there's a plug in the right side manifold just above where the pipe hooks up looks like it has a 15/16" hex on it but now a hole in it about 3/8" dia. Does anybody know what goes there.
Old Jan 18, 2016 | 10:32 AM
CaptainJack_7's Avatar
CaptainJack_7
replace the stock manifolds with shorties or LTs and cut out the cats
eco
Aug 20, 2006 08:05 AM
grogant
1978 - 1996 Big Bronco
Oct 16, 2003 08:04 PM
david9862
Oct 16, 2003 10:26 AM
Talled20
Sep 27, 2003 02:28 AM
tmh
Nov 3, 2002 10:20 PM
