Sponsored by: Auxito
Hard starting
Old Jan 14, 2016 | 06:35 PM
racin's Avatar
racin
Hard starting
So after work tonight I went to start truck it turned over fine but wouldn't start, when it finally did it barely ran and then it was fine, I had it b4 when I start it would turn over for a little bit b4 starting, would that be fuel pump?
Old Jan 14, 2016 | 10:22 PM
steve(ill)'s Avatar
steve(ill)
when you turn the key on, the fuel pump should run for 3 seconds and pressurize the line ... if it does this again, turn the key on, wait 3 seconds, turn off, turn on , wait 3 seconds, etc.. do this 2-3 times, then turn the key to the "start" position and see if that fixes your problem........ each time you turn the key "on" listen for the pump to kick in and run for 3 seconds......
another thing you can do is check the fuel pressure at the Schrader valve on the fuel rail above the motor after setting all night.
super fly
42
May 6, 2013 11:31 PM
jorge.s
Jan 14, 2012 07:33 PM
barngoddess
Oct 18, 2011 01:11 PM
rudy11hoops
2004 - 2008 F150
Oct 14, 2008 09:12 PM
