Offroad & 4x4
t-case operation
Old Aug 8, 2003 | 05:28 PM
19903024x4's Avatar
19903024x4
t-case operation
in have the borg-warner t-cause in my truck...manual waren hubs and my t-case is manual.........no where can i find operating instructions for the t-cause..........all i want to know is what i need to do when shifting in to 4x4 hi or low........i prolly can't do a shift on the fly can i?
Old Aug 8, 2003 | 08:16 PM
RRMike's Avatar
RRMike
t-case operation
With the hubs locked in you should be able to shift on the fly to 4hi as the front drivetrain should already be turning the same speed as the rear. You can try it and see it won't hurt anything it will just grind if it won't work but I'm sure it will. To go to 4 lo you should have to be doing less than 5 mph I would think.
Old Aug 9, 2003 | 02:18 PM
mrwizard's Avatar
mrwizard
t-case operation
Going into 4-Lo usually requires that you are stopped and either in nuetral or park.
jayc3169
Nov 2, 2021 11:26 AM
ashshade
Feb 18, 2008 08:12 PM
tmdata
1983 - 2012 Ranger & B-Series
Dec 12, 2004 12:37 PM
MJD
Apr 3, 2004 03:34 AM
CO4x4SD
Aug 19, 2003 07:34 PM
