Heater issues- maybe 2 problems- searched but...
The truck in question is my e99 with the 5.4 gas, standard heater controls. The truck is always on the road now that college is in session, so I either have limited time to look at it, or it's just not here. I got to my college (just started! Woohoo!) in the morning, and I live close enough that it doesn't fully warm up before I get there anyway. I come home around noon, then the wife takes off for her college- it's after dark when she gets home.
Issue #1- My wife has reported that it's only putting out heat under load. If she lets off the throttle, comes to a stop, or coasts down a hill (even at freeway speeds- it quits blowing heat and blows cool air. She also says that when it is blowing heat, it's just "warm" air, not "hot" air like it used to. She says the temp gauge is in the normal range, in about the same spot it's always been.
I don't know if this problem just started or if it's been slowly degrading, because prior to the cold snap a couple days ago, it hasn't been that cold out PLUS we weren't driving as much prior to this week (before our schools started).
ALSO, last week when it was warmer, I did a little bit of PM to the truck, anticipating the extra driving once school started. From that little bit of PM, I can add the following information:
1) There was no evidence of coolant in the oil.
2) There was no evidence of oil in the coolant.
3) The degas bottle was right at the full mark.
4) All the hoses were in good condition with no evidence of leaks.
5) Truck parks in the same spot every time- there has not been, nor is there now, any coolant on the ground.
6) There is no issue with a leak in the ESOF system: When I switched to manual hubs, I removed those lines and sealed their ports.
Like I said, I haven't looked at it yet, as I didn't notice the issue with my short trip time to school. But since it's dark and cold when she gets home, I'd like to make my time looking into it as short as possible.
Issue # 2- This one I did notice: It doesn't seem like the fan blows as strong as it used to. I still have all fan speeds, but now on high, I can barely feel the heat out of the dash vents if you hold your hand about where the steering wheel is. Last winter, when my hands were cold, I'd aim the two dash vents towards the steering wheel and it'd be like my own personal blast furnace on my hands. Now I can barely feel the air movement.
Last year, I had installed a brand new blower motor assembly, and when I had it apart, the area looked free of debris or obstructions. At the same time, I replaced the blower motor resistor. I would think the resistor would be fine, as I still have distinct blower speeds.
My best guess is that these are two separate unrelated issues. I say that because even if I had hot air all the time, it's still blowing at a reduced volume, AND I would think that even if my blower speeds were normal, it'd still be cooling off when not under load.
Obviously, issue #1 is the most important to me. Last year, you could leave the blower on low and it would still heat the truck fine- it just took longer to do it. Right now in this weather, we can't seem to get the cabin warmer than about 45 degrees. And there's no smiley for freezing and shivering....
heater motor going bad... or is loosing power or its ground...
all speeds work but at a slower rate???
Good Luck
I put an aftermarket blower motor in my old van and it never had the speed that it had before.
Does it matter if you've selected MAX AC or one of the other modes?
Can you tell any difference in either the volume of the airflow or the sound of the airflow when switching modes?
Did a flush on the heater core only, not the entire system. Heat returned with a vengeance.
How well has the cooling system been maintained?
He has two separate but seemingly related issues, he needs to do the checks I described above.
Coolant was changed and the radiator flushed when I got the truck, what- 3 or 4 years ago? Since then, I've checked the level and mixture since then. Level was last checked last week.
Thanks for all the advice- I'll be checking it out tomorrow and I'll report back what I find.
