Slow start check engine light
Old Jan 12, 2016 | 05:28 PM
Cgl45's Avatar
Cgl45
I have a 2000 f350 7.3 got a check engine light that turns off when rpms go up and a slow start. My mechanic said that there were no codes being blown any suggestions what is going on? thanks
Old Jan 12, 2016 | 05:40 PM
HKusp's Avatar
HKusp
If you are getting a check engine light, there is a soft code that is being stored. If he can't read it, he has the wrong scanner for our trucks.
Old Jan 12, 2016 | 05:49 PM
Cgl45's Avatar
Cgl45
yeah I had a feeling someone was going to say. any educated guesses? If not thanks for the quick response. he was able to pull the codes for the bad injectors and a few other things.
Old Jan 12, 2016 | 06:26 PM
z31freakify's Avatar
z31freakify
When I had this happen to me it was the IDM. Get it scanned and report back
Old Jan 12, 2016 | 06:31 PM
Cgl45's Avatar
Cgl45
I already replaced that lol. Thanks guys I appreciate any input I can get running out of ideas
Old Jan 13, 2016 | 08:46 AM
Strokerboy73's Avatar
Strokerboy73
He can't read it with a basic car scanner, check your battery's might be time for new ones. My old ones fully charged only held 12.1 and threw a PCM memory loss code, after two new battery's it's a whole different start up. And make sure your terminals are clean
Old Jan 13, 2016 | 08:53 AM
HKusp's Avatar
HKusp
With those symptoms I would certainly check all connections and make sure they are clean and tight. Pay particular attention to the battery cables themselves. They can get corrosion in the weave of the wires, You might want to try cutting back a little of the insulation on the wires and see if there is any green chalkiness mixed in with the braid. If there is, you will want to replace them. But if they check out, I would have the batteries load tested as well as your alternator.
Old Jan 13, 2016 | 05:30 PM
Cgl45's Avatar
Cgl45
I will check that out thanks for the advice. They are new batteries so maybe it is the wires causing problems.
Old Jan 14, 2016 | 03:44 PM
Cgl45's Avatar
Cgl45
So it is a bad turbo!! FML! Any suggestions on were to get a new one? Should I upgrade or stay stock? I already put a bunch of money so I don't really want to break the bank
Old Jan 14, 2016 | 04:02 PM
Pikachu's Avatar
Pikachu
What led you to that conclusion? A bad turbo shouldn't cause a long crank to start.
Old Jan 14, 2016 | 05:33 PM
HKusp's Avatar
HKusp
^^^^What he said....I am not seeing the correlation at all.
Old Jan 14, 2016 | 05:42 PM
Cgl45's Avatar
Cgl45
Ok so the slow start was from the EBP (p0476)that was replaced starts better now. But the check engine light was still on and the last code on the list was something to do with the turbo. I will get the code from him tomorrow.
wrdabney
24
Aug 26, 2012 04:03 PM
jv2290
Dec 2, 2010 07:49 PM
riverratba
2004 - 2008 F150
Mar 26, 2010 06:24 AM
BoomerPower
Apr 30, 2005 05:50 PM
alopez2
Nov 29, 2004 06:54 PM
