transmission slipping 2011 f250 gas 4x4
bought last year with 65k miles, now has 105k. sometimes when accelerating it slips for a second like a manual would if you jabbed the clutch while pulling. i had the 100k trans flush done. i noticed it a couple times before but more frequent recently. how concerned should i be?
on
I just had my fluid changed in my 2012. I immediately noticed a bit of slipping from reverse to forward at times. Took it back to the shop that did the change and they pulled 3 litres out of it saying it was overfull. It slipped again once about a week later. I checked the fluid level and its still overfull. I am going to a different tranny shop now to get them to check and probably remove more oil.
Crystal
