Dana 60 front rebuild
I am about to tear into my 79 kingpin dana 60 axle. I have everything figured out except where to get a rotor that is the entire hub assembly as well. This axle has really badly rusted rotors and hubs so I want to replace it all. Anyone seen the rotor and hub sold as a single unit? I want to keep the 1/2" studs to match my new rear axle. If need be ill see if I can salvage my original hubs but last time I had the axle out if I remember correctly they didn't look to good.
Ill post pics when I bring the axle home this coming week if my work schedule doesn't get to busy.
Yea I saw those. For my 79 bronco I got the rotor with hub and studs for like 70 bucks piece. Cant seem to find anything for the 60 so ill just have to try and reuse the originals. Bead blast the outside and check the inside and I think they should be good. The rotors are toast though....
Caliper wise isn't the 78/79 HP dana 44 caliper the same on the 60?
I am about to regear the 60 and was looking at torque specs, do these seem right? Some seem ridiculously high.
<table width="900" border="1" cellspacing="0" cellpadding="3"><tbody><tr><td width="42%">Pinion bearing preload (new)</td><td width="23%">20-30</td><td width="85%">inch pounds</td></tr><tr><td width="42%">Pinion bearing preload (used)</td><td width="23%">8-10</td><td width="85%">inch pounds</td></tr><tr><td width="42%">Pinion bearing HP60 used in rear</td><td width="23%">12-20</td><td width="85%">inch pounds</td></tr><tr><td width="42%">Backlash</td><td width="23%">6-10</td><td width="85%">thousandths of an inch</td></tr><tr><td width="42%">front wheel bearing freeplay</td><td width="23%">1-10</td><td width="85%">thousandths of an inch</td></tr><tr><td width="42%">Ring gear bolt torque</td><td width="23%">110</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Bearing cap bolt torque</td><td width="23%">80</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Cover bolt torque</td><td width="23%">30-40</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Pinion nut torque</td><td width="23%">240-300</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Cover fill plug</td><td width="23%">40</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Yoke U-joint bolts</td><td width="23%">8-15</td><td width="85%">foot lbs</td></tr><tr><td width="42%">wheel brg adjusting nut</td><td width="23%">50</td><td width="85%">foot lbs - then back off approx. 90°</td></tr><tr><td width="42%">wheel brg locknut</td><td width="23%">50-70</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Kingpin </td><td width="23%">500-600</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Upper and lower kingpin cover bolts</td><td width="23%">70-90</td><td width="85%">foot lbs</td></tr><tr><td width="42%">Spindle nuts (the ones that hold the spindle to the knuckle.)</td><td width="23%"> 65</td><td width="85%">foot lbs</td></tr></tbody></table>
Sean Balboni
23
04-09-2013 08:02 PM
Steve
02-24-2007 05:21 AM
