Injector problems
Old Jan 8, 2016 | 11:18 PM
Firetruckmark's Avatar
Firetruckmark
Injector problems
Hello,
I have a 1997 f250 with the 7.5l 460. I was driving down the road and hit a small pot hole and truck started sputtering. Was able to limp it home where I have ran several checks on it. Here's what I know.
-good spark to all 8 plugs
-raw gas is dripping from tailpipe and exhaust manifold.
-I have gas in my engine oil
-my engine is running on 4 cylinders(1,4,5,&8 only)
-I have tested the fuel injectors and only cylinders 1,4,5,& 8 are pulsing
-In moving the injector wire connector from the good injector on cylinder 1 to the not working injector on cylinder 2 it made cylinder 2 active. which tells me the injectors are good but the electrical circuit could not be.
What I think I can conclude
The injector circuit for cylinders 2,3,6, & 7 is not completing to close the circuit for pulsing the injectors on these cylinders only.???
or I have a short in the wiring???
or bad PCM???
Can any one help me with further diagnosis pointers?? I'm stuck in a rut on this one. Thanks.
Old Jan 14, 2016 | 12:55 AM
wtroger's Avatar
wtroger
These are bank / batch fired injectors. For what ever reason you have lost the ground for the other half. Check the connectors for loose or corroded connections. Or the PCM took a dump.
Old Jan 14, 2016 | 08:41 PM
Firetruckmark
Thanks for the help Wtroger. I checked the wiring at the injector plugs with the pcm plugged in and both wires of each injectors where reading 12v. Unplugged the pcm and no 12v to both wires. So I had to be the pcm. I changed it out and she runs like a champ! Thanks again!
Rwm8082
Feb 28, 2019 09:43 PM
Harry Ziegler
May 28, 2014 06:01 PM
c4jlca
Jan 13, 2013 03:32 PM
Ratkat
Aug 29, 2008 05:36 AM
19704X4F250
1983 - 2012 Ranger & B-Series
Jul 5, 2008 08:53 PM
