Installed Dynomax VT on my 5.0 today
on
I am curious as to how much back pressure the Dynomax VT gives when the valve is closed and how much performance gains there are. I have the MBRP 3'' cat back system with their resonator. It is quite loud (straight thru design), but the performance gains are quite noticeable. Even with stock tuning, it gives the impression of having a tuner installed.
on
I did a lot of reading on many of the different muffler brands/designs. Straight thru designs give the best performance gains. Anything that reduces noise tends to reduces performance, also. There is an optional muffler from MBRP that reduces noise, but at the expense of performance. Since I was more concerned with low-mid rpm performance (towing), I am staying with the straight thru design and quickly getting accustomed to increased noise level in the cab. BTW, my system actually quiets down some at higher rpm (interstate cruising).
adgjqetuo
2017+ Super Duty
37
11-21-2019 11:18 AM
sum_weirdo
Exhaust Systems
16
05-24-2008 11:29 AM
Tall Paul
01-10-2000 03:44 AM
