Fuel tank sending unit
Have a 66 f100 with an in cab tank. My gas guage reads full all of the time until it's completely out of gas then it will move slightly down but still close to full. I guess my question is how can I tell if it's the fuel guage (aftermarket) or the sending unit.( I'm guessing original) that is creating this problem. Any help is appreciated!
Take the wire off of the sending unit, turn the ignition key ON, and see what the gauge does. Then, with the key still ON ground the wire and see what the gauge does. If it doesn't change then it is the gauge or the voltage regulator for the dash. The regulator usually affects all of the gauges though.
You can also remove the sending unit, hook it up to an OHM meter and run it through the range from full to empty and watch the meter readings. The readings should increase or decrease steadily.
There's a chart at the bottom of the page.
Fuel Tank Sending Unit Tech - FORDification.com
Lotsa stuff on youtube.
hoss73ford
08-11-2015 10:47 AM
azaeldrivesford
12-31-2011 04:31 PM
