LED fog light question
Old 01-06-2016, 03:35 PM
davidmh47's Avatar
davidmh47
davidmh47 is offline
I'm looking at installing Rigid LED fog lights on the 2015 I just bought. Do they plug into the factory harness so that you can control them with the fog lights switch or do they wire separately with their own switch?
Old 01-06-2016, 07:28 PM
EricRom's Avatar
EricRom
EricRom is offline
They do not plug into the factory harness, but when I had them installed they just tapped into the factory wiring of the fog lights so that they could be used with the factory switch. I have the SAE D'2 and they are great.
Old 01-07-2016, 03:11 PM
JetExpress_6.7's Avatar
JetExpress_6.7
JetExpress_6.7 is offline
A harness that is plug and play can be had from a company called KD Fabworks...or you could make your own up if you can find the appropriate plugs.
Plug-and-Play LED Light Adapter Harness H10/9005/9006
Old 01-08-2016, 12:08 AM
davidmh47's Avatar
davidmh47
Great info, thanks for the reply
Old 01-11-2016, 08:58 AM
shadetreezj12's Avatar
shadetreezj12
shadetreezj12 is offline
Old 01-11-2016, 05:30 PM
Michael53's Avatar
Michael53
Michael53 is offline
Shadetreezj,
With this install, it appears that these lights that replace the stock fogs only come on with lights in DIM and the **** pulled out for Fog. Is that correct? If so, seems these might blind other drivers. I would like them to only come on with High beams. Did you rig yours this way?
Mike
Old 01-11-2016, 06:23 PM
shadetreezj12
Originally Posted by Michael53
Shadetreezj,
Mike
Stock set up. Angled down slightly.
I'm still free from bullet holes.
Around town, I don't run them.
Old 01-11-2016, 09:23 PM
JetExpress_6.7
Yes they plug directly into the factory wiring so headlights on dim and **** pulled out is the only way to turn them on.
That is unless you wired them into a relay that is triggered by your high beams. It would be the direct opposite of the OEM configuration, headlights on high and fogs come on, headlights on dim fogs go off.
Old 01-13-2016, 09:22 AM
rtazz17's Avatar
rtazz17
rtazz17 is offline
I kept my stock ones and installed the rigid ones on either side of liscence plate and connected them to upfitter switch.I turn them on only when theres no opposing traffic even though I have them angled down and inward they are still blinding and have gotten plenty of people ticked off when ive forgotten to hit switch off.I also installed the rigid floods on my rear bumper.They work great.The stock reverse lights dont throw enough light for me to see through my tinted windows when backing.
Old 01-13-2016, 09:56 AM
MG250's Avatar
MG250
MG250 is offline
Do you have a picture of this?
I would consider the same.
Also, what did you mount the lights to? Directly attached to the bumper?
This may be the solution to my desire for extra lighting on unlit highways at 3 AM.
Supercab
08-14-2014 08:04 PM
Pool Guy 23
1999 to 2016 Super Duty
04-26-2014 01:02 PM
barnhill910
2004 - 2008 F150
08-21-2011 03:25 PM
pullinair
02-01-2009 09:07 AM
F350-6
11-19-2007 10:50 AM
Quick Reply: LED fog light question
