Won't start
Old Jan 6, 2016 | 01:40 PM
spudgi's Avatar
spudgi
Won't start
Ok so the title isn't completely true. It starts. But when it's cold it takes a couple tries. When I say cold I mean Cali cold. Like low 40s. BUT when I have her facing downhill she will start up every time on the first try. What could be causing this?
Old Jan 6, 2016 | 01:49 PM
navistarnut's Avatar
navistarnut
Anymore info?
Year?
Miles?
Recent work?
A way to monitor data live? ICP and IPR when cranking would be nice to know
Early build, most likely your HPOP is going south towards the border.
Old Jan 6, 2016 | 01:52 PM
spudgi's Avatar
spudgi
2003 (12/02 build) 125k new tranny 4" exhaust new injectors studded bulletproof egr cooler and oil cooler.
Why would gravity effect the HPOP?
Old Jan 6, 2016 | 01:57 PM
navistarnut
That's right you had ICP issues last week?
Welcome to the club of the early build weak a$$ HPOP's.
It likely starts easier facing downhill because your not draining the pump and losing your seal/prime.
Only way to know for sure is an air test, but my money is on the pump.
Recently studded?
Old Jan 6, 2016 | 01:58 PM
spudgi's Avatar
spudgi
2 years ago oil cooler went south and it effected everything. How much we looking on install this?
Ya fresh ICP
Old Jan 6, 2016 | 02:01 PM
navistarnut
Yourself? $1000 or under with stock pump. A shop will charge mucho dineros with labor and mark up thrown in.
Go with a good pump, Adrenaline would be my choice(with I had looking back), but they are over a grand for sure last time I checked EDIT...........still at a grand. I think the OEM is around $700.
It's not that bad a job, but will take some time for the DIYer
Old Jan 6, 2016 | 02:02 PM
spudgi's Avatar
spudgi
fantastic!
Old Jan 6, 2016 | 02:05 PM
navistarnut
Well, it's either that or you end up with an STC fitting, dummy plugs or standpipes, or all three on the later builds
Old Jan 6, 2016 | 02:12 PM
spudgi's Avatar
spudgi
I have no clue what any of that is
Old Jan 6, 2016 | 02:15 PM
spudgi's Avatar
spudgi
When it's been started at least once that day it starts no problem no matter the temperature.
Rod Jr.
Jun 1, 2019 10:48 PM
VictorwithaC
Aug 5, 2016 06:55 PM
SHAWN056.0
Sep 13, 2010 09:33 PM
selmacpa
Feb 5, 2008 06:12 PM
tomtoc
Sep 17, 2007 08:26 PM
