Sponsored by: Auxito
Climate control quits after startup
Old Jan 6, 2016 | 12:03 PM
Alex_B's Avatar
Alex_B
2003 F150 Super Crew. I replaced a dead battery and now notice the climate control quits working (blacks out) after a few seconds, and a battery light comes on the dash. If I turn the truck off and wait a moment and then restart, the climate control will light up and work but after a few seconds, same thing, it blacks out and quits, battery light on the dash.
Any ideas?
Alex
Old Jan 6, 2016 | 01:19 PM
steve(ill)'s Avatar
steve(ill)
battery light normally means the alternator is putting out less voltage than the battery. You replaced the battery, but do you know the alternator is good ? Measure the battery voltage while running ... should be over 13.5 volts.... bad alternator, or you have a bad wire / ground for it/
Old Jan 8, 2016 | 10:35 AM
Alex_B's Avatar
Alex_B
I will be testing the Alternator output this weekend, I am confused why this incident is not affecting other electrical systems other than the climate control.
Old Jan 8, 2016 | 08:12 PM
steve(ill)'s Avatar
steve(ill)
good question.......... but your main concern right now is " battery light is on"... fix that first.
Old Jan 8, 2016 | 08:16 PM
steve(ill)'s Avatar
steve(ill)
blower motor can pull quite a few amps... maybe it is kicking in and pulling more than the alternator can put out.
Old Jan 14, 2016 | 01:08 PM
Alex_B's Avatar
Alex_B
So after waking up to a dead battery three times, I have determined that the truck is suffering from some parasitic electrical draw. There is some good youtube videos on this situation that will help determine what systems are drawing excessive power when the truck should be off. I will found out more this weekend.
Old Jan 14, 2016 | 04:23 PM
steve(ill)'s Avatar
steve(ill)
why does the battery light come on ????????
66with352
1997 - 2003 F150
Aug 11, 2024 10:42 PM
medic25
Dec 10, 2012 02:20 PM
mgf250
Aug 5, 2010 08:29 PM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
swamprat
Electrical Systems/Wiring
Jan 15, 2006 02:11 PM
