What's the difference in ignition modules?
Old 01-06-2016, 04:26 PM
Harkijr's Avatar
Harkijr
Harkijr is offline
So I'm curious. If they're year-specific, what exactly makes them year specific? I know that year-by-year the wiring changed a little bit. My guess would be that I could buy any year module, as long as I'm very careful to run the right wire to the right wire.
Originally Posted by 84espy
Will you show pics of your engine?
Espy, I posted some pictures on my profile. Have at it!
Old 01-06-2016, 05:12 PM
TheMonson's Avatar
TheMonson
TheMonson is offline
Originally Posted by Truck Noob
if i remember correctly rockauto.com has the motorcraft ones for @$40.
They do.
I'm also curious about this (now). Mine is a 75 but has the blue grommet module. I was going to order a new Motorcraft one as a backup, but it looks like mine should (according to the year) be a green grommet.
Old 01-06-2016, 11:35 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
If I were you I would look for a NOS (new, old stock) one on ebay. I'm told the new ones from China are crapola, like the distributor p/u modules from China, good for 3 years, when the motorcraft ones lasted 40 years!
Old 01-06-2016, 11:47 PM
Harkijr's Avatar
Harkijr
Harkijr is offline
I try my best to stay away from China made. On this truck I'm definitely not cutting corners.
The following users liked this post:
Old 01-07-2016, 12:07 PM
Filthy Beast's Avatar
Filthy Beast
Filthy Beast is offline
Maybe a late, late '75 model, assembled in early '76? The blue ones started in '76 and stayed up to the late '90s I believe.
If it works well, no problems with it, why worry about it?
Old 01-07-2016, 12:12 PM
TheMonson's Avatar
TheMonson
Oh I'm not worried about it per-se, just wanted to pick up a spare and get the right one.
Old 01-26-2016, 02:40 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,348 Likes on 1,142 Posts
My '77 still has it's OEM Motorcraft Ignition Control Module. I've had the truck since 35,xxx miles in 1986.
Some time maybe a year ago or more I was driving along and it just cut off like you killed the ignition .... but a few seconds later it was OK. I later found a fuel hose with a crack, replaced it, no more cutting off .... until this morning as I was on a slight down grade. Lights, all stayed on, radio stayed on, like you just cut ignition ..... but maybe 4-5 seconds later it come back.
Buddy at work says it's the ICM .... I went ahead and bought a BWD Select CBE-7 ICM as a back up just in case .... and then I remembered I had a spare that had been in the truck since the 1980s .... so I went out and got it. Haha .... it had leaked some of it's potting stuff out into the box ..... but I'm sure sit's still good. I'll try it to see ..... but I'll also keep the BWD as a newer backup.
Old 01-26-2016, 08:25 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Interesting that the expert parts boys haven't posted up. .. unless the only thing they can say that they have different PNs.
Old 01-26-2016, 09:25 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,424 Likes on 2,542 Posts
I am waiting on him too.....
dwhawkins89
12-22-2017 07:07 PM
Jon Hinds
04-05-2012 09:22 AM
sum_weirdo
07-18-2007 01:26 PM
marty60
06-24-2007 05:08 AM
vans1951f1
04-08-2005 06:46 PM
Quick Reply: What's the difference in ignition modules?
