What's the difference in ignition modules?
I'm on LMC truck looking at ignition modules, and they have different modules for different years. They have a 1974, 1975, 1976-77, and 1978-79 module. What's the difference between each one and does one have an advantage over the others?
My truck is a 75, the motor is a 460 out of an 88. I'm completely redoing all the wiring and ignition, so any wiring issues that would keep me from using a certain year wouldn't be a problem.
Jared
Jared
Jared
Jared
According to "the man":
Ignition modules, 74 (black grommet) and 75 (green grommet) are year specific and will not interchange. 76 to 79 (blue grommet) are interchangeable.
Ignition modules: 1974 is 1974 ONLY / 1975 is 1975 ONLY.
Blue module introduced in 1976 was used well into the 1990's.
D4AZ-12A199-C 1974 only
DuraSpark ignition modules identified by a colored plastic insert located above where the wires feed out.
2 others: One has a*red*plastic insert, the other has a*yellow*or*brown*plastic insert.
Red*module is*D7AZ-12A199-A*used in some CA vehicles ONLY.
D9AZ-12A199-C*(replaced D8AZ-12A199-A). One of these modules is*yellow , one is*brown*.. Since the part number was replaced, I cannot recall which module was which color.
These modules were used in 1978/79 302 & 351M/W vehicles sold in high altitudes only. 351W: Passenger Cars & Econolines only.
1U2Z-12A199-AA*(replaced D6AZ-12A199-B - D7AZ-12A199-B - D8VZ-12A199-A - D9VZ-12A199-A) .. Ignition Module -*blue*insert (Motorcraft*DY-893) / Available from Ford.
Myriad 1976/90's FoMoCo vehicles.
Green Sales in OH.
Collectors Auto Supply in WA.
Haven Ford in KS.
Klimesh Motor Sales in IA.
Bob Allen Ford in KS.
Freese Motor Inc in IA.
Wesley Obsolete Parts in KY.
Dennis Carpenter Ford in NC.
Green Sales in OH.
Haven Ford in KS.
I'm curious if aftermarket modules use the same color grommets to identify them. I go to lots of parts swaps & find new ones in the box, but never knew how to ID them, as they all have their own part # on them. If the aftermarket has the colored grommets, I'll pick a few up as spares. Often they are really cheap, & are made in the USA, not communist China.
