The Blue Goose's build thread.
And honestly at this point if I have to destroy another paycheck to get this darn thing running I'm going to loose my mind, so that's what we are going to do later today. Gonna pull the pan, fill it will oil, check, mark, and drain the good oil back into a container and put the nice "fill plug" in the pan and call this thing done.
HOWEVER! Once I get that ability back everything i have taken so far will be uploaded.
Of course I find out about this amazing feature now...........meh I never claimed to be smart, i just know enough to be dangerous with a keyboard and a wrench.
Allot of my pictures were junk, turns out auto-focus works allot better if you give it 5 seconds to focus.
But for reference to anyone else using a 351W and M5OD I went to Advance Auto and got a flywheel (28oz) For a 1990 F-150, and for the clutch I am using a stock F150 clutch for the 351W, being that most of them were behind the zf-5's they seem to have a much thicker clutch material on it, allot better of a bite by the looks of it and would fit on a 5.0 if you needed a cheap upgrade without going out to summit racing.
Now I will say one thing, getting this thing lined back up, was a PITA job. i fought with it for two hours trying to get it slipped up enough for the bolts to fit on one side but could not get both sides threaded in, so what i did was I told a slightly longer bolt with about a 1/4 of washers (was all I could find with Auto-zone closed and what I had on hand) and worked it up side to side like that until the bell-housing was up against the block. Then I removed my alignment bolts that I made up to keep the bolt holes lined up on the top of the trans (Three inch long bell-housing bolt with the head of the bolt cut off) and tighten it all up with the proper bolts.
Now the pan plug is about where 5.0 quarts of oil would level out give or take a few, its mainly a reference plug should I be out on the road and I feel as if its losing oil or I need a top off and want to be sure i didn't overfill it. Me and dipsticks never really got along for some reason.
I did make one change to my plan, instead of fighting the duraspark setup and all its wiring I'm going to instead use an all in one coil and dizzy two wire setup and just call it done. I don't need an extra item to fight me when i still gotta plumb up the fuel system and honestly, I'm just to lazy to do all that mess of work when I'm just gotta thrash on this thing once it's all broken in and we know we have nothing to worry about engine wise for some time.
Will get some better pictures after work of what I got going on in the engine bay right now.
Also since I got some folks around watching this thread, what would be a good wire to tap into that's key on power, but will stay on while cranking? I'll need that for the Two wire Dizzy.
Thank you all once more
Shadow
P.S. we ain't even close to done..........
Last edited by Shadow944795; Jan 31, 2016 at 11:17 PM. Reason: I didn't like a few things I did so i fixed em.
Use heavy primary wire (at least 12Ga., probably #10 is better) for the 30 & 87 terminals.
This is in the instructions of every one of these distributors I've ever seen.
In regards to the nut and pan setup she will sadly not be a daily driver. At best, until I build up funds or get another project started and have to daily it, will only end up being a weekend toy. I did not do the sight glass because funds are tight and I'm tired of buying all this stuff that is junk and won't work for some weird little reason or it will work and cost me another paycheck and then some to order everything. That and I got impatience because i thought it was gonna get put together sooner than later. My plans never go as I like.
As for the fuel system, that is something to note. Did you use a return style setup? Or did you end up just running the main feed line when you tried the EFI pumps? I'm curious so I know if I should bite the bullet and buy the right pump now and spare the issues of a over-pressure situation before I can even crank it over.
Now I will throw in some info just for others who may do this same swap. I used a carb throttle cable for my setup off of an 84 F-250, this is what I got allot of my stock carb items, for the most part this all will interchange with a brick-nose give or take a few items since the Bullnose shared allot of stuff under-hood. The bracket I used for this was just an auto-zone adjustable linkage with a kick-down piece if you used an AOD, I am not so I took it off and played with everything until it fit up to the holly for my liking. I noticed there was a notch on the holly that the stock cable could fit on so that worked good and from what I can tell the bracket lined up really well and seems to be a clean looking setup. The bolts that hold the throttle cable to the cab are 8MM and it was allot easier than it looked to swap it out, i thought it was gonna be a PITA to do it.
The belt I used was a 91 inch belt to bypass the smog pump and keep the A/C and PS on this truck Although if I even went straight up drag only I would loose both in a heartbeat.
The damage to the alternator bracket was my own screw up I had a power-steering bolt in the hole (thread pitch and bolt size are the same shockingly) and ran it up didn't realize that something was off until "SNAP", so dad ,managed to tig it up and make it work again, it was either that or I went and got one from the junkyard for cheap.
I also ran all of my main battery wiring like my ground back to where it needed to go and did crank over the engine just a bit to see if the starter would mesh up okay with the 351W flywheel and to make sure it worked still since it got covered in a snow drift on the ground without me knowing until it was to late to do anything. Worked just fine only needed to recharge the battery and maybe even see about a better ground cable for the battery since well I forgot how crusty it looked 0___0.
Radiator is still out but I did connect up my heater hose connections with some 1/2 copper pipe. I got a few more pictures of a before deburr and after but basically what I did is chopped up four pieces of copper pipe, and used the burtex well to clean them up and used hose clamps to put it together. My reason for creating thing connection was because i needed a hair more hose on both ends to reach everything and I did not want to run new hose to my heater core or break off an end if I could help it. So that is what I did. And I only needed to use two of the pipes, the other two are in my toolbox for another vehicle or if I need them again for something else.
No fuel lines pumped yet, that is tomorrow nights projects.
The two wires with a little red sharpie on the black connector from what I gathered from just looking at the wires for the old coil and its wiring loam they are what i need for my Tach source and a key on power for the relay that will control power to my new dizzy that came in.
That new dizzy is also not in. The engine is not at TDC for cylinder number one (ended up that way when I put the flywheel on) so that is something else for either tomorrow night or Saturday when I get back on it for sure.
The list is getting smaller and I soon see this truck once again rolling under its own power. Sadly before I can take it farther that up the street I gotta get it inspected again. GRRRRRR I hate yearly inspections. But I do understand that they are needed for people who won't maintain their own cars.
Also one other thing to note the picture of the starter is there for a reason. I did not use starter bolts. i couldn't find them, but header bolts are the same thread and size and hold that thing in there perfectly. so remember that if the starter falls out in the middle of nowhere.
