6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L bible
Old Jan 4, 2016 | 09:02 AM
nathan66669's Avatar
nathan66669
6.4L bible
Everywhere I looked I could not find the actual 6.4L bible (like the 6.0L) just the Ford power point labeled as the bible.
Here is the actual bible:
http://www.powerstrokediesel.com/doc...ble%20Book.pdf
Also, I had a lot of trouble getting the link to the cab removal/head gasket/HP fuel pump walk through to load, so I consolidated it to a PDF.
All credit goes to BlackSnapOn from Ford Truck Fanatics. He posted every picture for us to enjoy. If this comes in handy, hop over there and thank him. He did a ton of work to make this very easy to follow.
6.4L cab removal, engine head teradown and high pressure fuel pump removal:https://drive.google.com/file/d/0B4J...ew?usp=sharing (5.5mb file)
Old Jan 4, 2016 | 01:14 PM
speakerfritz's Avatar
speakerfritz
thanks
can the lifters be removed with cab off and engine still installed. I know the CAM's removal require engine removal...but Im not clear if the lifters will come up while engine is still installed.
Old Jan 4, 2016 | 02:31 PM
nathan66669
I believe the rear cover needs removed to access the lifters/camshaft through the rear of the motor. If that is the case, no matter what the tranny needs pulled, cab off or on.
Personally I have never had to access anything related to the cam, so I am by no means the expert there. If the cam needs removed, I am certain the cab off/tranny pulled would work. I would assume cam needs removed to access, and if thats the case, I would think just pull the motor instead of the cab and tranny. Someone else would need to tag in though.
What is wrong with your lifters? Maybe some background would help.
Just FYI, Ford has pretty much said they won't touch a truck with a lifter ticking based on the sound alone: Sticky Lifter - Ford Powerstroke Diesel Forum
Old Jan 4, 2016 | 02:38 PM
nathan66669
Oh, and if the lifters *DO* come out the top, you would need the heads off.
It is possible to do head job on a 6.4 with cab on, however if your doing that just so you don't need to pull engine, then that is a whole lot of extra time plus $$$ for parts. Head gasket kit runs a few 100 plus studs are 4-500 and misc gaskets etc.
Old Jan 4, 2016 | 03:16 PM
speakerfritz
I had the ticking/thump noise that a lot of folks caputred on a few you tube videos. After doing a flush and draining the oil and refilling with new oil...the ticking / thump noise went away. if it comes back will probally have to throw bigg money at it before I would be comfortable driving long distances. is a 2010 f-450 6.4L with 85K miles on it. runs fine with 15W40 in it, if I put 5W40 in it it sounds like someone is shaking a tool box and the ticking / thump noise is worse.
I know that the engine has to come out to change the cam, which is sometimes damaged by bad lifters in 6.4's. but I was not sure if you could replace lifters with out pulling the engine.
Old Jan 4, 2016 | 04:17 PM
nathan66669
I've only ever used Rotella t6. Some people had luck putting in some atf. I would recommend Mobil full synthetic atf and try that before doing any teardown.
These motors require better oil, api cj-4 if I recall. But better quality is always better imo
Old Jan 5, 2016 | 12:52 PM
nathan66669
I watched a few youtube videos and saw the lifters do come out the block from under the head. There is black plastic retainer with I believe an m10 bolt in the pushrod cavity. I did not touch it on the 6.4 I did but I believe if you unbolt that they either pop right out or use a magnet on a stick from the top.
If this is indeed the case, you can replace them without pulling cab or motor. Just be aware that if the lifter is bad there is a good chance of creating uneven wear on your cam and possibly leading to needing a new cam as well. But again, your talking a decent amount of money to do a head job. It would really suck to go through that much effort and still need a new cam (which would require pulling the heads again).
Old Jan 5, 2016 | 12:56 PM
speakerfritz
yes...that makes sense...I've seen the magnetic tool to lift the lifter out.
and yes...catch the lifter failure early would avoid CAM related problems. right now...no metal has ever appeared in my magnetic sump drain or in the magnets within my metal screen oil filter.....
Old Jan 5, 2016 | 08:12 PM
73fan's Avatar
73fan
I did the cam on my engine. I pulled the cab off, pulled the motor out, and instead of removing that heads (I didn't want to spend the money on head gaskets and such) I removed the oil pan and fished those lifters out with a magnet.
It's a real pain, but it is possible.
And yes, if you remove the heads, you can unbolt the little black plastic things called a lifter guide and take the lifters out the top.
I would be very worried about camshaft condition if a lifter has gone south. But when you have the lifters out, rotate the cam so the lobe with the bad lifter is visible. From there you should be able to see if the cam is damaged or not.
Old Jan 6, 2016 | 07:31 AM
Tractionless's Avatar
Tractionless
Curious to know what you flushed with. Thanks!
Snellville-Dave
Jan 27, 2017 09:24 AM
MBDiagMan
Dec 13, 2015 01:52 AM
the_auto_tech
Oct 16, 2012 09:44 PM
AndeyHall
Jul 21, 2011 10:00 PM
phil85207
May 19, 2008 12:26 AM
