Lincoln Navigator subwoofer specs?
Depends on the amp, if the amp is rated 2 ohm stable and you bridge it, then it needs minimum 4 ohms in bridge mode. 2 vs 4 ohms isn't really that important when talking 2-300w subs. 300w in 2 or 4 ohms sounds the same, the only difference is the amp. That Pioneer mentioned above doesn't require anything major to drive it, and if you go with that amp I linked you'd have to bridge the amp and wire it to 4 ohms. When you're diving into large systems, then it gets more important to go with lower impedance, even down to 0.5 ohms in huge systems.
I was talking about the factory amp... being 2 ohm stable and the factory sub in a 2003 is 2 ohms per channel.
I have never owned a "typical" amp... all of my stuff has always been PPI, Orion, Xtant, etc... very easily take .5 ohm stable bridged.
rdalley
05-08-2008 10:56 AM
mudguy33
12-08-2005 10:05 PM
fordtrucklover94
12-13-2004 10:36 PM
bullard2003
12-28-2003 01:02 AM
bengleu22
09-03-2003 03:06 PM
