'96 F250, Charging question
Hi all - I'm new to diesels but just picked up a '96 F250 XLT Supercab, 2wd to use as a tow mule for a large boat. We plan on buying the boat late in 2016, so I've been watching craigslist for a good deal on a tow vehicle. I got a good deal on the truck, it's only got 230k on it and the driveline has been well maintained and never modified. Cosmetically it's rough but livable, and it needs a lot of minor peripheral work. I'm fixing all the mechanicals and functional issues, but I'm not too worried about cosmetics, at least not yet.
Anyway, on to my charging question. When I first crank the truck the voltmeter reads low. Once I get the RPMs up, like driving to the end of the street, it's steady just above the halfway mark, right where I would expect it. After that it stays right where it should even when sitting at idle for a while.
The serp belt was making a lot of racket when I bought the truck so I slapped a new one on - thought it was slipping until warmed up. No change in voltage but it is much quieter.
Both batteries look very new, group 65 Interstates. No problems cranking - it fires right off. Cables are clean and in good shape.
I suspect either the regulator (on the alternator) or the alternator itself are going bad, unless you guys tell me this normal for these engines. I've wrenched on stuff for 30 years, and it certainly doesn't seem normal to me but this is my first oil burner.
I don't mind replacing the alternator given the prices at Rock Auto, but I'd hate to do it if this is a "feature" and not a "bug."
Also, how do you tell if you've got the 65amp or the 130? With power windows and such, I'm guessing the larger but ...? If it is the 65, is the 130 a bolt in swap?
Thanks guys. Stay tuned for more dumb newbie questions.
Dave
Dave
Dave
Dave
Not sure if this helps, but keep in mind that the glow plugs can run up to 2 minutes...and that is a huge drain on the electrical system.
Thanks guys!
Okay, that makes sense. See, it's the little stuff like that makes this kind of forum valuable.
Here's a pic I took on the way home. She's scruffier than it looks here, but she runs great. My wife named her Blue Bell.
So far I've fixed a bunch of small stuff, cleaned the interior and threw on some seat covers. Biggest problem so far is that it needs tie rods all the way across and ball joints. Those parts should be here this week, along with a bluetooth transmitter for Torque. I've got all the stuff for an oil change and a fuel filter too, just to start from zero.
What's a good place to find test strips for SCA in the coolant? Does NAPA have them?
PsD007.3
18
04-09-2009 09:52 AM
