Help!
Old Jan 3, 2016 | 05:33 PM
Smashleigh's Avatar
Smashleigh
Help!
Alright, we have an '89 F150, it was a farm truck and had sat for some time. We've just finished putting a new intake manifold and gasket, deleting all admissions, valve cover gasket on. Now, like I said before, it's sat for some time. Our problem now is it runs, but the oil pan is fillIng with water instantly and then it stalls. We know that more than likely it's the head gaskets but, since admitting thats the problem and putting in new heads (which as I'm sure you all know is an incredible pain in the a$$) we were wandering if anyone else has dealt with a similar problem, and if so, what that might be?
Old Jan 3, 2016 | 05:43 PM
danr1's Avatar
danr1
You didn't mention which engine you're working on?
What was the original reason for changing the lower intake gasket? you where talking lower correct?
If V8 and its running into the oil pan at that rate and yet not blowing any coolant out the tail pipe? It's possible its the intake gasket leaking coolant into the lifter valley and down into the pan, you ended up with the gasket folded over itself one corner perhaps?
Old Jan 5, 2016 | 09:30 AM
'89F2urd's Avatar
'89F2urd
Or a cracked block. Need more info
jwbdillinger
1997 - 2003 F150
Jan 3, 2009 09:07 PM
90F250351
16
Dec 5, 2006 05:35 PM
gollygwagen
Oct 4, 2005 01:23 PM
400miller
Apr 6, 2003 09:47 PM
fozzy
Dec 10, 2001 06:57 PM
