Aerostar Ford Aerostar
wrong plug on oxygen sensor
Old Jan 1, 2016 | 02:48 PM
zenish's Avatar
zenish
i bought a oxygen sensor from rock auto.my problem is that the plug is a little different.it has one of the two locating tabs in the wrong place.everything else seems the same.im wondering if i should ground the tab off.im not sure that the sensors work the same.thanks.
Old Jan 2, 2016 | 07:51 AM
Jose A.'s Avatar
Jose A.
it is obviously the wrong part for your vehicle. Return it, check with www.am-autoparts.com where they confirm the part with the VIN.
Old Jan 2, 2016 | 09:33 AM
zenish's Avatar
zenish
i went back and looked at the pictures of all the brands of oxygen sensors listed by rockauto for it.i read on the net that some cars have different connectors on each side so you can't cross up the oxygen sensors.only the motorcraft and acdelcos had the tabs[in the wrong place].the other brands were tabless and seemingly designed to work on either side.
Old Jan 10, 2016 | 06:44 PM
99f350sd's Avatar
99f350sd
I had to cut something off when I did mine..
Pmax
Mar 28, 2018 07:17 AM
timmyboy76
Oct 6, 2011 02:05 PM
MustangGT221
17
Jan 7, 2007 09:54 PM
scroller bill
1978 - 1996 Big Bronco
Dec 27, 2006 11:37 PM
druggist
Feb 2, 2004 08:14 AM
