Good morning Oregon and everyone everywhere else. 32.8° and clear here. It's going the wrong way though. It had been up to 41 and just a few minutes ago it was 33.3°. Clear skies, an orange UFO is rising from behind the Cascades and the Fortune Teller is saying it is going to be mostly sunny today with a high around 57 / 60, depending on which Fortune Teller you listen to.
So very true. In our little hole in the ground here, we create our own weather anyway. If you don't like what you see out the front window, just look out the back window! Although you will probably like that weather less.
Pat, you might go ahead and drop a line to whomever in the IT / Admin dept. for FTE that I am having problems with uploading and / or inserting pics.
When I click on the insert image, the screen comes up, I can select a pic from the HD or one of the albums, but when I click insert, nothing gets inserted.
The only way I can insert emoticons is to do a copy and paste. I can't just click on them like I used to.
Same problem I had some time ago. Don't know what they did to fix it then, but the gremlins have returned.
This is a picture my son took a while back of me and a couple of my toys. The model L tractor I restored a few years ago, the 6 hp hit and miss I purchased several weeks ago. I'll try to get him to take some pictures of last weekends fun.
Thanks guys.....
It was intact when I bought it, but a little beat up, it did run, but kind of rough....
It was painted some off breed yellow. I sandblasted it, rebuilt the engine, the rear differential and transmission were OK. I had someone do the body work, and paint the hood and fenders...I painted the rest of it. First time I ever painted anything like that. It certainly isn't perfect, but I was pleased with my end result.
