wiring harness interchange???
Old Dec 31, 2015 | 08:07 AM
majsservices's Avatar
majsservices
Exclamation wiring harness interchange???
hello all!!!!
new here but I have a VERY frustrating problem recently our 01 F-550 had a short in the lighting circuit and unfortunately this cause several wires in the main harness under the dash to fuse together and melted several pins at the firewall connecter the cause of the problem has been found and fixed(head light switch) but I am still in need of the dash harness. the problem im having is that its a discontinued part from ford so im having to search bone yards and parts trucks. The main question I have is what can work in this truck? are they all the same? I have found a couple of potential donor trucks but would like to know if any of these harness will interchange
A three trucks have 7.3L and are 2WD
My f-550 is a 01 build date:8/2000 no power options including cruise control and DTRL harness part number 1C3T14401-FC
Donor truck #1: 2000 F-450, build date 3/2000 no power options including CC AND DTRL harness part#: YC3T14401-ALL
Donor truck#2: 2001 F-350 build date 01/2001 no power windows or locks has CC but no DTRL harness part #:1C3T14401-DAC
So can anyone out there tell me if either of these will work? any input would be greatly appreciated!!! thanks
Old Dec 31, 2015 | 11:33 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Either harness should work but I would go with the F-450 donor truck since it has DTRL.
One thing for sure....the 02-03 trucks have a completely different harness so you want to avoid those models.
Good luck.
Old Dec 31, 2015 | 11:48 AM
slim613's Avatar
slim613
Originally Posted by Shake-N-Bake
One thing for sure....the 02-03 trucks have a completely different harness so you want to avoid those models..
when I had swapped mine after my engine build I used a 2000 model engine harness on a 2002 truck and one of the pcm wires was missin or one extra and causes the battery light to stay on it was about a year ago
second welcome to FTE this is a great place for question and some very friendly people
Old Dec 31, 2015 | 11:59 AM
slim613's Avatar
slim613
found my old post n this may or may not help but if u did come across this issue its a heads up
"i do have my battery light on and it is charging as well as starter, alt and batteries are new NOW while im here anyone notice a difference in a 2000 engine wiring harness VS a 2002 harness only difference i found was the orange and blue alt wires, one goes to brick plug of engine harness conector the other goes to the starter/battery 2000 goes from alt to batt 2002 is alt to brick plug of engine harness"
Old Jan 1, 2016 | 11:04 AM
Kwikkordead's Avatar
Kwikkordead
Post deleted
JR Connor
Jul 8, 2018 09:13 PM
wade427
Nov 16, 2017 10:46 PM
Austin Steinmann
Apr 30, 2014 01:56 PM
bucks77ford
Feb 17, 2007 06:58 PM
fords_forlife
26
Jun 25, 2006 03:55 PM
