alternator wiring harness help
FORDS_FORLIFE
The year of the harness you are putting into your truck is vital information. Are there any tags with part numbers on this harness anywhere? Located in the cab would be a good place to look. The tags are usually Red, have Ford on them and a part number for the harness.
Did the truck have guages, and the Bronco have idiot lights, or vice versa? There are a lot of differeces between the two harnesses, and they are not compatible without moderate/to expert wiring modifications.
FORDS_FORLIFE
Can you show me a pic of this troublesome connector ?
The connector sounds like it is for an 80's alternator.
Does yours look like this ?
THis is for a 78/79.
https://www.ford-trucks.com/user_gal...120685&width=0
This is the alternator, external voltage regulator type, correct.
https://www.ford-trucks.com/user_gal...120686&width=0
Voltage regulator
https://www.ford-trucks.com/user_gal...120687&width=0
This is a picture of the new wiring harness. it's like it has everything the old one did except for the connector in the first picture. the weatherpack connector in this picture has two wires where as the one i'm missing has three. i think this one would plug in to the two wire connector that you can also see in the first pic.
https://www.ford-trucks.com/user_gal...120688&width=0
I you need anymore pictures let me know
FORDS_FORLIFE
It isn't an Original Harness from what I know.
One with a 2 prong like you show and another with 3 prongs which you mention you don't have on this new one but do on the first image.
The wires are the key.
The two prong plug has a green/red stripe and a white/blk stripe.
The 3 prong has the large black/yellow stripe, ,a yellow,a orange
FORDS_FORLIFE
The only thing I can think of is why they are different is that either the wiring harness is for a truck with idiot lights, and the bronco has guages or vice versa, the wiring harness is one for guages and the bronco has idiot lights.
The connector that hooks up to the voltage regulator should point that out.
On a truck with guages:
Connector #204, plugs into the voltage regulator and the colors are...
1. - circut #35 - Orange
2. - circut #904 - Green/Red stripe
3. - circut #152 - Yellow
4. - empty.
On a truck with Idiot Lights:
2. - circut #4 - White/Black stripe
4. - circut #904 - Green/Red Stripe
And also according to the wiring diagram, there are several other major differences,
Trucks with guages have more connectors, than trucks with idiot lights.
Trucks with Idiot lights:
Circut #152 yellow wire goes from the voltage regulator to splice #203. from there the wire changes to circut #38 Black/Red stripe wire, and one wire goes to the Altenator, and the other goes to the starter solenoid.
Trucks with guages:
Circut #152 yellow wire goes from the voltage regulator to splice #202 where the wire changes to circut #38 Black/Red stripe wire, and circut #655 Red/Orange stripe wire.
Circut #655 Red/Orange stripe wire goes from splice #202 and goes to connector #206, and from there goes to the instrument cluster connector #208A and the ammeter.
Circut #38 Black/Red Stripe wire from splice #202 goes to another splice #201, where circut #37 Black/Yellow, and circut #654 Yellow/Black stripe wire split off.
From splice #201 the circut #38 Black/Red stripe wire goes to the starter solenoid.
From splice #201 the circut #37 Black/Yellow, goes to Connector #206, then leads to splice #208 where nothing splits off, and continues to splice #402, where the circut changes to #21 Yellow, and from there goes to connector #412 at the ignition switch.
From splice #201, the circut #654 yellow/black stripe wire, goes to connector #206. and from there goes to connector #208A at the instrument cluster, and the ammeter.
So with all this information, the wiring harness for the idiot lights would be missing Connector #206,
And the wiring harness with the guages would have connector #206 that has three wires going into it.
1. Circut #37 Black/yellow
2. Circut #654 Yellow/Black
3. Circut #655 Red/Orange
And there are yet even more differences, but I would have to write a book.
So if what I'm thinking is right, you have the wrong wiring harness, and need to get one that fits your truck, or change out your instrument cluster for the idiot light pack.
Hope this helps.
Connector #208 is the instrument cluster connector for idiot lights.
Connector #208A is the Instrument cluster connector for guages.
They are different connectors, and I have a sneeky suspicion that if you try to connect your instrument cluster into the new harness that it wont plug in.
FORDS_FORLIFE
The numbers that I posted earlier are found on the FORD wiring diagram. They won't be found on your harness. I posted them so if you have a wiring diagram, you could trace the circut yourself using a diagram. Also with the numbers, you you can follow each circut easier, (at least for me) than if I just sprout off colored wires.
There are several major diferences with wiring with a truck with Idiot lights than there are with guages. Including how the altenator is hooked up to the voltage regulator.
The voltage Regulator itself turns on a idiot light by how it's wired.
and if the truck has an ammeter, the wiring for the guage is hooked into the altenator wiring, using a connector #206 on the wiring diagram.
The voltage regulator for a truck with idiot lights will have FOUR seperate wires going to it and plugging into it.
1: ORANGE
2: White/Black (Comes from the stator)
3: Yellow (this wire is doubled)
4: Green/Red
The voltage regulator for a truck with guages will have THREE seperate wires going to it and plugging into it.
1: ORANGE
2: GREEN/RED
3: Yellow (This wire is doubled)
4: This place is empty in the plug.
Notice the stator isn't hooked up to the voltage regulator, on a truck with guages,
But the stator IS hooked up to the voltage regulator for a truck with idiot lights, cause the stator wire, triggers the idiot light in the dash to turn on.
On trucks with guages, you will also note the GREEN/RED wire has swapped places from #4 to #2 and the #4 spot on the regulator is left empty.
One harness is not compatible with the other.
I still think this is your problem, but since the instrument cluster plugged in, I would say the harness to the altenator isn't the correct one now. Is this one also original or is it different too?
I will do some more research, I have Ford Bronco Diagrams as well.
You are missing a connector on one of your wiring harnesses. One with three wires in it correct?
the connector has three wires in it:
1: Yellow/Black
2: Red/Orange
3: Black/yellow
Is the colors correct? Which harness is missing this connector? The altenator harness or the Main Harness?
What color are the two wires going out to the connector for the two wire conector?
I bet they are:
1: White/Black
2: Green/Red
