6.9l Performance Upgrades?
Old Dec 31, 2015 | 12:01 AM
Jake Herman's Avatar
Jake Herman
Hello everyone, will some of you idi gurus give me a hand? I got a 1984 F250 6.9 ext. cab long bed 2wd with 200-220,000 miles, banks turbo, 3" straight pipe side exit and just recently replaced the head gasket. Also its automatic with a gear vendor. I want to know if there's any real big power getters out there, but I heard there ain't much. Any suggestions?
Thanks, Jake.
Old Dec 31, 2015 | 12:13 AM
Ford F834's Avatar
Ford F834
The big power getters out there are more fuel (higher output IP) and more air (better turbo set up and Intercooler). However to add much more than what you already have you are going to want to stud that 6.9. Check out http://www.idiperformance.com
Old Dec 31, 2015 | 12:38 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Did you install headstuds when you did the gasket? If not there isnt alot you can do without adding them.
Which banks turbo? 90cc pump, and turned up wastegate should get you comfortably over 200whp, little more with an intercooler. In a perfect setup you can expect 240rwhp or approx. 300fwhp
Old Jan 7, 2017 | 12:04 AM
Jake Herman
No I did not. I think I'm gonna cam, stud, fuel, and a 5" exhaust
Old Jan 7, 2017 | 07:31 AM
jayro88's Avatar
jayro88
Just remember you need enough air to burn the fuel. You may have to upgrade the turbo to match the fuel.
Not sure if the 5" exhaust will get you anything.
Old Jan 8, 2017 | 07:44 AM
cadunkle's Avatar
cadunkle
Indeed, that'll just be a nuisance to run and source pipe and clamps. Anything larger than the downpipe is a waste. 3" or 3.5" if you have more than one bend for a longer run over the axle is fine, more won't get you anything.
Old Jan 8, 2017 | 10:15 AM
genscripter's Avatar
genscripter
Agree with Jayro and cadunkle. I upgraded to a hi-flow Walker straight-thru muffler and that didn't really add any horse, but it brought my egt's down 200-300 degrees. But 5" exhaust seems ridiculous.
Old Jan 8, 2017 | 10:19 PM
SpencerS's Avatar
SpencerS
i have heard good things about propane injection, someone else on here did a home-made setup for like $200 or something and had noticeably more power. but there are also kits for it that you can buy
Old Jan 11, 2017 | 06:55 PM
hairyboxnoogle
Cam will get you a little, ditching the C6 will free up a bunch too, those things rob an insane amount of power.
To make a realistic gain in power tho, you need studs, and a bigger pump
Old Jan 11, 2017 | 07:40 PM
Macrobb's Avatar
Macrobb
Which is great until you realize that propane is competing for the same air as the diesel.
The /only/ time you will get a benefit out of propane injection is if you aren't giving it enough fuel. On a NA engine, you just need to adjust the IP to give yourself enough fuel.
On a turbo engine, it might be useful if your turbo can supply more fuel than your IP can deliver... but then you still have to worry about pinging, as you aren't direct injecting it*.
Really, though... just buy a bigger IP. Then you can control the timing correctly.
* Note: I'd be really interested in seeing a liquid-propane injected diesel engine. Chances are you could literally run it on straight propane, and I'll bet it would be awesome. Much faster burning than diesel.
Old Jan 11, 2017 | 09:18 PM
Charmalu's Avatar
Charmalu
Propane has around 110 octane, more than gasoline, but less BTU`s.
Diesel has more BTU`s than gas or propane.
Propane 91,000 BTU
Gasoline 124,000 BTU
Diesel 139,000 BTU
I have read on some Forum`s adding propane will help give the engine more oomph...
How ever, I have a 67 1 1/2 ton International Harvester truck. Back in the 70`s I had it on Propane. We were hauling a 2 Horse Trailer, two horses and camp gear from Sea Level ( which she ran pretty good ) up to the Dodge Ridge area of Calif. then back into the hills on dirt roads for 10 miles for a week long trip.
Climbing up to probably 3000 ft or more, that truck kept loosing power, and I kept shifting to a lower gear.
Thought I had a plugged filter or something...
It was just that the propane did not have the BTU`s to give the power I needed.
So running a Diesel engine on straight propane might not give the results you might hope for. Maybe the higher compression of the engine might make a difference...IDK.
Charlie
Old Jan 11, 2017 | 09:35 PM
Macrobb's Avatar
Macrobb
I'm pretty sure that if you can get enough fuel in there and aren't leaning out, it'll do just fine.
Remember, though, that no matter what your BTU/gallon rating is, you can always add more air and fuel... in an engine like this, the limit is more how much force the connecting rods can take(or the headgasket in the case of a non-studded engine).
With a NA engine, you might lose a little performance due to the lower BTU rating, but I've heard it's like 10% if that(according to professional kit manufacturers).
I'm thinking that the main gain with propane vs diesel in a compression-ignition engine would be the faster burn time, so it would be able to rev higher with good torque, which equals more HP.
Old Jan 12, 2017 | 01:46 AM
88 Ford IDI's Avatar
88 Ford IDI
The only way I would run propane on an IDI is as a supplement on an engine with a bigger turbo that will make use of the additional fuel. Overall, from what I have read, is that propane has a similar affect as water/methanol on an IDI. It also can cool egts and make more power as a supplement.
Due to the faster burn rate, like Macrobb mentioned, I would make sure an engine is timed ideally with the propane. That is unless it is a minimum amount and doesn't have that great of an affect on the injection event. IMO there is a similar issue with methanol but its affects are minimized due to the water being injected at the same time...
Old Jan 13, 2017 | 09:03 PM
AlaskanWheeler's Avatar
AlaskanWheeler
Propane is usually injected in addition to the diesel fuel that is already being provided by the injection pump. So if these numbers are correct, your total BTU's being supplied to the motor will be 230,000 BTU's. That is a considerable amount...
What propane does for diesel's is exactly what Nitrous does to a gas motor.
Propane 91,000 BTU
Diesel 139,000 BTU
Old Jan 13, 2017 | 09:20 PM
Macrobb's Avatar
Macrobb
*sigh*
BTU numbers are thermal energy per gallon. Good for comparing energy /density/, but not for engine power. Mainly because you aren't dumping a gallon of fuel into the engine at a time.
You are putting a measured amount of fuel per cylinder/injection cycle. Yes, if you inject the same exact amount of a different fuel, you may get different amounts of power.
But, you can always compensate by adding different amounts of fuel.
The problem is simple: Air. That's the limiting factor. Just adding fuel won't help you, it just creates smoke.
This applies no matter /what/ you add. Propane isn't an oxidizer.
Even with a gasoline engine, you don't just 'add nitrous'. You add nitrous(an oxidizer) AND spray a matching amount of gasoline down the throat. If you don't, you lean the engine out. This is what makes the power - not the nitrous, but the combination of gasoline plus nitrous(fuel + oxidizer).
On a diesel, you don't need to worry about leaning the engine out, so you can add more oxidizer if you want... but it won't help without extra fuel to burn. Conversely, you can turn your IP up as much as you want, add more fuel, or even add propane, gasoline or anything else, and all you will get is smoke. Because the limit is air(oxygen).
A good example of this is performance diesels. Watch the exhaust - They are blowing tons of black smoke(lots of extra fuel) until they hit the nitrous. Then, the extra oxidizer combines with the extra fuel creating lots of heat, power... and you'll see the exhaust clean up because of it.
Also, lets say you got a turbo(more oxidizer) that gives you the capability for more HP, but you don't have enough fuel. Sure, you could add propane... Or just add more diesel.
Plus, if you add enough propane to really make a difference, the heat from compression /will/ ignite it too early, and you will be putting a lot of shock into your connecting rods because of it... and probably not making much power.
BTW, I /have/ actually run an IDI on straight propane. I managed to get it to idle with a hose stuck down the throat with the IP /off/.
Problem is, even at that speed and relatively low heat, it was clattery due to the preignition.
There's a good /reason/ that gasoline engines(which inject the fuel in with the air charge) have to have a much lower compression ratio(which lowers efficiency) than a diesel engine which injects the fuel after the compression has already happened.
Propane on a diesel is basically just a stop-gap measure used when you have more air than fuel available from your IP. And I'd expect that it'd work better with a lower-compression DI engine than a higher-compression IDI due to less chance of preignition.
SOE
Apr 30, 2015 01:02 PM
forddieseltech08
Nov 19, 2012 06:35 AM
hick51
17
Nov 2, 2011 12:43 PM
FL-Mudd-Duck
Jul 29, 2009 07:32 AM
redneckmechnic
Oct 24, 2003 08:11 PM
