Bad gas mileage.
Bad gas mileage.
So I recently bought myself a 93 F150 5spd 4x4 5.0 with 196k miles Truck is darn near mint.. one scratch on the whole body zero rust and no gunk or mess anywhere in the engine bay or underneath.. was a one owner vehicle that had reciepts for every repair back to 93 Everything but the transfer case transmission and lower end of the engine has been replaced or rebuilt.Recently its getting 8mpg The truck does have custom 3" exaust thats all brand new. The check engine light comes on only when its warmed up I am getting a code 33 and code 52. So i replaced the TPS and cleaned and checked the EGR with a vaccum.. Drove it for 20 miles then the light came back with the same codes? Any suggestions for the horrible MPG.. The tires are all properly aired up and brand new the brakes are brand new and adjusted properly.. tomorrow i plan on checking plugs an wires to make sure the shop that did them 12k miles ago did them right. Im a jeep guy so this ford truck stuff is really foreign to me lol Thanks for any help guys.
well here are some pictures.. So i called the old owner an he claims the muffler shop didnt want to connect the EGR pipe to the exaust manifold because it gives less horsepower.. So where does that connect?? Crawling around on wet concrete in the dark is challenging enough on its own haha
Well being winter doesnt help much either.. And really the exaust? I thought more air in more exaust out made better MPG?.. The truck runs great tho! Takes very little effort to get to the end of the speedometer.. and it never hesitates or stumbles when getting there. But even when im driving like a grandpa its still 8mpg..
12k ago do a complete tune up on it, all to often guys skip things to save a few bucks. Prime example "plug wires" come to mind.
3" system is overkill for it but doubt its adversely effecting fuel economy, to a small degree perhaps but not effectively cutting in half.
196K a compression test wouldn't be a bad thing get a reading of the overall condition of things, a vac gauge would also give a quick impression how things are going internally. A strong vac reading with a steady needle is a good thing.
Might find everything is in good shape but the base timing hasn't been checked/set, that alone can kill fuel mileage. Check timing chain verify within wear limit, if original never been molested and at that mileage it might be a tad to "long" at this point!
Anyway point is don't assume anything, look at and check everything and make sure it is as it should be.
Timing chain was done with the clutch 27k ago and the water pump.. and a few other things. Yeah guess ill learn about distributors and tune ups on fords tomorrow or friday! woohoo! And as for the compression test any way to do that yourself? Im not much of a vehicle mechanic in knowledge.. i fix other mechanical things for a living so diagnostics and wrench turning never scares me.
Yes you can and should do it yourself its the sure way to get accurate results.
I gonna cheat a little bit and post a link rather than type it out,
Engine Compression Test Instructions - You Fix Cars.com
Any questions just ask, plenty of guys willing and ready to help here pretty much 24 hours a day.
Nice looking ride, must be you don't live in the rust belt (your location isn't showing in your posts)
What size tires are you running and you might want to check the differential has the hear ratio tag on it or check the axle code on the door for what gears it has. It looks like you may have taller than stock tires if so there is a small part of your mileage. Incorrect odometer reading will cause your math for mpgs to be off.
