engine removal
Old Dec 30, 2015 | 06:17 PM
therigwelder's Avatar
therigwelder
engine removal
I am removing my 7.3,do I have to remove the turbo or can I just disconnect the down pipe. Also what is the easiest way to undo the motor mounts?
Old Dec 31, 2015 | 09:22 AM
tjc transport's Avatar
tjc transport
i ain't rite
just disconnect the down pipe. granted removing the turbo would give you more wiggle room, but it does not have to come off.
for motor mounts, just unbolt them from underneath
Old Dec 31, 2015 | 03:44 PM
therigwelder
good the turbo dosen't have to come off. I spent 4 hrs trying to getting that ******* off. the motor mount bolts are the 2 bolts 1 on each side of the crossmember per side.
Old Dec 31, 2015 | 04:15 PM
tjc transport
i ain't rite
yup. don't forget all the wires and bell housing bolts too
Old Dec 31, 2015 | 08:01 PM
ReBilld's Avatar
ReBilld
Two studs on each side with nuts on the bottom. You have to get to them from under the motor mount.
Old Dec 31, 2015 | 09:08 PM
therigwelder
The two with the nuts on the underside of the crossmember? I took the two bolts out that looked like they separated the top of the mount from the bottom .guess I messed up.anyone got a picture?
Old Dec 31, 2015 | 11:44 PM
91 Dually's Avatar
91 Dually
I think either way will work. I just thought it easier to remove the nuts from the studs like Bill said
Old Jan 1, 2016 | 01:20 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I would agree. You can't really see what your doing but you can see them before you get the socket and your arm up there
howellt39
May 20, 2013 08:30 AM
bayromer
Jan 26, 2009 09:30 AM
dmueller71
Mar 25, 2007 12:27 AM
tjbeggs
Nov 11, 2005 09:03 PM
nuclearmonster
18
Apr 5, 2004 01:30 PM
