Pulleys won't fit
Old Aug 7, 2003 | 08:33 PM
UglyBeast's Avatar
UglyBeast
Question Pulleys won't fit
Did they make different diameter water pump and crankshaft pulleys for different years? I got a reman 81 351w and a milodon high vol alum water pump. The problem is that the water pump pulley won't go on the water pump because it has no room over the crank pulley. The water pump bolted on fine. I suspect that the motor I pulled was not the original and may have been an older motor. Any suggestions?
Old Aug 12, 2003 | 10:38 PM
pinellas50's Avatar
pinellas50
Pulleys won't fit
There are difenately different sizes of pulleys for crank, water pump, and alternators. I don't see how the high volume water pump itself could have anything to do with this problem as you should still be using the same pulley from before.
Two possibilities come to mind. First research your vehicle, mabey by VIN through the dealer, to find out what is supposed to be there. The other is to get a set of aftermarket pulleys such as the multitude of underdrive pulleys available.
Good luck.
Old Aug 14, 2003 | 07:42 PM
UglyBeast's Avatar
UglyBeast
Pulleys won't fit
Thanks, I bought a aluminum regular volume water pump from NAPA, and everything bolted on fine. The Milodon must have been wrong from the factory. Even the bolt pattern for the pulley was wrong
Old Aug 14, 2003 | 10:21 PM
pinellas50's Avatar
pinellas50
Pulleys won't fit
Yeah, I guess if someone sold you the wrong pump that could do it too. Glad you got it straightened out.
kydavison
Aug 16, 2020 03:47 AM
jvettoretti
Oct 18, 2016 09:09 AM
Boss50
Sep 28, 2016 04:05 PM
T_Cooksey88
Aug 12, 2016 08:24 PM
yellow 79
Apr 1, 2009 05:24 PM
