Complete lock set
Old Dec 25, 2015 | 02:12 PM
subford's Avatar
subford
I do not know about your local locksmiths but all the locksmiths around where I live will not touch re-pining the locks unless you provide all of the parts they need to do the job.
That includes the pins (wafers), nose cap and the wafer cap(if ignition).
I had change the combination myself for the Ignition to match the doors as my wife did not want to carry two keys for the truck. Took the wafers out of the old cylinder and put them in the new cylinder.
My door lock on my F250:
Old Dec 27, 2015 | 01:59 PM
Bird-Dog 250's Avatar
Bird-Dog 250
I haven't tried to get the locks decoded yet at a locksmith. I used to do VW locks way back in the 80's so I guess I could try the locks on the Ford. Prying the bezel off doesn't look like it goes back together too pretty.
Old Jan 1, 2016 | 06:18 AM
Bird-Dog 250
Originally Posted by subford
Are you saying your 97 door locks are like the 1995 & some 1996 door locks?
I tried to get a locksmith to rework the locks. Can't find one that will do it.
Back to the replacement locks.
Yes mine look like the ones in your photo! Gona check that place out next.
Old Jan 1, 2016 | 05:56 PM
ncranchero's Avatar
ncranchero
I did that myself as well although my cap removal wasn't quite that brutal. The big thing for me was recrimping the cap. I bought a tool to do it with and although the cap was a bit big for the tool I did get it back on without fubar-ing it up. I paid $45 + for the tool but it can be yours for less.
Old Jan 2, 2016 | 05:40 AM
Bird-Dog 250
I don't know what i'm doing!!!! At this point I'd like to just buy a doors and ignition lock set so I guess I'm still looking for someone that sells what I'm looking for. It seems like it should be easier to do than it is!
Old Jan 2, 2016 | 07:08 AM
ncranchero's Avatar
ncranchero
As I say, I'm not a locksmith but locks are interesting to me so like most anything I'll give it a shot. Nothing difficult about these except that darn cap. They make replacement caps that have 3 or 4 tabs on them that can be put back on MUCH easier than the original cap. I should have went with that instead of buying a tool and trying to use the original. Junkyard locks are a dime a dozen and you can build an assortment of wafers, procure the replacement caps and you're good to go. It's a matter of originality/challenge vs cost. I'm poor/cheap and love a challenge so "🎼 I did it my waaaaaaay.🎤"
Old Jan 3, 2016 | 01:17 AM
pasanby's Avatar
pasanby
Ford Ignition Switch Lock Cylinder 3 Three Door Lock Cylinders w 2 Logo Keys | eBay
Old Jan 3, 2016 | 06:43 AM
Diesel_Brad's Avatar
Diesel_Brad
It is pretty simple The link that subford posted earlier is the seller that has the OEM FORD parts for under $100
Here is another one of his listings. If you cant find Exactly what you are looking for, Contact him and he will help you out
http://www.ebay.com/itm/Ford-1992-95-F150-F250-Pick-Up-Ignition-Door-Lock-Cylinders-w-2-Keys-Black/151933913126?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3D46f7bb548b974eefaf314da0e06e91e5%26pid%3D100011%26rk%3D5%26rkt%3D10%26sd%3D161927752133
Old Jan 3, 2016 | 07:11 AM
My4Fordtrucks's Avatar
My4Fordtrucks
This seems like a lot of trouble just to carry one less key on the key ring. The ignition lock cylinder takes all of 30 seconds to replace (as long you have a functional key) and the door locks may take an hour combined. I have had a couple Broncos and if memory serves me correctly even my '94 still needed the round key for the tailgate. You could have had them replaced by now but to each his own.
Old Jan 3, 2016 | 08:04 AM
subford's Avatar
subford
The round key is also used on my 1993 F250's glove box lock but the door and the ignition use the same key.
Old Jan 3, 2016 | 08:29 AM
My4Fordtrucks
Ah. Forgot about the glove box lock since I never lock it. I beileve the console also uses the round key.
Old Jan 3, 2016 | 08:41 AM
tjc transport's Avatar
tjc transport
i ain't rite
Brad, would this setup work in the 87-91 trucks to get rid of the dual keys?
Old Jan 3, 2016 | 09:32 AM
  #28
Diesel_Brad
I am pretty sure if the ignition switch is the same between the 87/97 and the 92/97
Old Jan 3, 2016 | 11:04 AM
  #29
subford's Avatar
subford
THE Ignition Lock Cylinder was the same for the F-series from 1980-1991.
Then a different Ignition Lock Cylinder was the same for the F-series from 1992-1995.
Then again a different Ignition Lock Cylinder was the same for the F-series from 1996-2007.
Old Jan 3, 2016 | 11:08 AM
  #30
Diesel_Brad
yes, bronco used the same round key from 78-96
But the 92+ trucks only use ONE key for the doors, ignition, console and glovebox
