Ran my 05 for 10 years and pulled a 5er app. 14k when loaded and never had hg issues. Now turbos, that's another story.
Ditto. I still have to pull my turbo out and replace the unison ring.
I too haven't replaced my head gaskets and don't use a tuner, even when pulling a 15,500 trailer.
Remember that the 6.0 uses only 4 head bolts per cylinder, unlike the bulletproof 7.3, using 6 bolts, hence the concern.
I have a 150k on my 03, still with the bolts. I tow 12k from time to time along with my camper. I use windrunner Street or white noise tune daily with the Atlas 40. I did do a 4" straight pipe, blue spring, ec1 coolant, updated degas cap and a coolant filter.
If it ain't broke, don't "fix" it! There are many people who might suggest that you have to "bulletproof" (terminology) your truck.
I think about 85% of the reason that these engines need to be studded is because of EGR cooler leakage. If you live in a state without emissions testing on diesels, delete the EGR cooler and drive it! If you have testing, replace the stock cooler with a Bullet Proof EGR cooler from Bullet Proof Diesel in Phoenix, AZ.
Someday if you must remove the heads, then stud them when you do the repair.
That whole "bulletproofing" gimmick has been used in the diesel repair industry for years. They see puking and immediately jump to the extreme when the EGR cooler is what actually has failed.
Dorman now makes a "bulletproof" style EGR cooler for a fraction of the cost of a BPD branded one. It may help you in a bind.
You really do a disservice to the 6.0 community by not claiming the lack of miles you actually drove and the amount of sitting your truck in fact did.
By saying you needed a turbo every 20k, someone might think that was 10 turbos in 200k miles, when in reality how many turbos was it, 3 in 60k?
Just sayin'....
Josh
Your correct in the mileage Josh however when ran it got worked and moisture is not much of an issue in S. Ca. If it were me then I don't think Ford would have bought it back unless they have seen this trend before. You shouldn't have to work the pi** out of a vehicle everyday in order to maintain a healthy turbo. Also as I've stated before, I do think the 6.0 is a robust platform with a misguided rep. do in large part to ill trained techs when it first hit the market until a learning curve had been established. To add to it's problems the general public thought this diesel could be idled for hours like the pre-smog diesels with maint. done every 50,000 to 100,000 miles when in fact it does require an almost **** amount of maintenance. If mine had not been re-purchased I would still be driving it and for the most part enjoying it. I will also state that it never did leave me stranded.
I wouldn't go as far as to call the 7.3L "Bulletproof". They've had their share of issues. I've owned one, I know. Aside from being weaklings, they develop fuel leaks, have injector issues, the HPOP system isn't 100% and they are backed with the god awful 4r100 and E4OD automatics.
I averaged a turbo every 20,000 miles. That's why Ford now owns it.
Sounds like you didn't do your homework and was taken advantage of by whomever told you your turbo was bad, over and over again. I'll be willing to say that you probably didn't change the oil and filters when you should have and even then, I'll go one further and bet that it's likely each one of those turbos just needed a cleaning.
You are 100% wrong on all counts. Oil was changed every 5,000 miles or 6 months with 5W40 synthetic oil and OEM filter. On further note the turbos were replaced under warranty by the dealer and they did try to rebuild the last one for sure and it fell on it's face with a new center section. You should have gone to Vegas and bet your hunch. You'd be dead a** broke.
By the way, it also had the upgraded oil feed tubes,
I bought my 04 new, my head gaskets blew at 45k towing 24' trailer around 7,500# ford would not install ARPs but "new improved bolts" Ha Ha which stretched out at 78k towing the same trailer, stock. now it's studded and with all the BPD goodies and at 140k it's been trouble free. I've been driving it with a street tune, and towing with a tow tune, if you're going to keep it, stud it and enjoy it. good luck
The way I think, studs are needed when you are putting the heads back on. I don't think I could, in good conscious, put my truck back together with the torque to yield bolts. On the other hand I wouldn't tear it down just to put studs in either.
Maybe someday it will squirt out a headgasket and I can stud it. As a consolation prize I'll buy a tuner and start playing with tunes. That would make me feel a little better about the work and expense.
Sure, because everything you read on the internet is the truth, right?
