Sponsored by: Real Truck
Cab light plug location
Old Dec 18, 2015 | 10:26 PM
Btoddsmith's Avatar
Btoddsmith
I have a 2014 f250 ccsb. I have bought a oem cab light kit off of eBay. The wiring harness that came with kit is for an older truck and want work .my question is does anyone know if I can pull the wire pins out of wiring harness and put into a plug that's on truck ? If so which plug ? My lights are mounted but interior is in pieces and I have to get back on the job tomorrow , Thanks in Advance
Old Dec 19, 2015 | 03:01 AM
JoeyCap's Avatar
JoeyCap
I ordered mine that came with the correct harness. It makes it much easier. The harness also runs the wires for the air bags in the pillars, so you should be carefully about cutting or splicing anything.
Once you get the correct harness, everything will plug in without having to cut or splice.
Old Dec 19, 2015 | 07:34 AM
Btoddsmith's Avatar
Btoddsmith
Yea , the only wire that would get spliced or piggybacked would be the hot wire to lights . The other wire just gets grounded . The wiring harness that's there now would remain because of air bags and sat antenna. The correct harness is $80 from local dealership was trying to avoid that
Old Dec 19, 2015 | 12:54 PM
TexasRebel's Avatar
TexasRebel
Don't avoid that.
Old Dec 19, 2015 | 12:58 PM
wrvond's Avatar
wrvond
Is there an open connector in the pillar? It would seem an easy thing to identify an unused wire that gets 12VDC when the lights are turned on. Alternatively, you could connect to an up fitter switch.
Old Dec 19, 2015 | 02:34 PM
Btoddsmith's Avatar
Btoddsmith
I really wanted it to look like it came from factory so I guess I will be ordering correct harness
gundamman
Aug 7, 2017 12:38 AM
microbc
Feb 3, 2017 04:15 AM
robd928
May 18, 2011 09:37 PM
smashclash
Jan 23, 2011 01:53 PM
