Sponsored by: Auxito
Bad miss under acceleration
Old Dec 17, 2015 | 01:06 AM
roundheadlightsonly's Avatar
roundheadlightsonly
i have a 97 f150 with 4.2 4x4 auto. i have a bad miss under acceleration. if i ease on the gas no problems. stomp it and it chugs and pops back thru airbox til it gets to 2500 rpm then clears up. if i shift it manually and keep rpms up its fine till it gets below 2500. i have replaced spark plugs, plug wires, fuel filter, upper and lower intake gaskets, cleaned injectors, new air filter and cleaned o2 and mas sensors. had vacuum system checked and was told all good. if anyone has any ideas i would greatly appreciate the help
Old Dec 17, 2015 | 05:13 PM
steve(ill)'s Avatar
steve(ill)
and no code light ?
Old Dec 17, 2015 | 06:34 PM
pdqford's Avatar
pdqford
Coil Pack?
Old Dec 17, 2015 | 06:35 PM
pdqford's Avatar
pdqford
Coil Pack? ? ?
pdqford's Avatar
pdqford
Coil Pack..............?
Old Dec 17, 2015 | 06:36 PM
pdqford's Avatar
pdqford
Maybe the Coil Pack?
Old Dec 17, 2015 | 06:37 PM
pdqford's Avatar
pdqford
Coil Pack?
Sorry about that. My computer started to stutter.
Old Dec 18, 2015 | 10:03 AM
roundheadlightsonly
coil pack replaced also
Old Dec 18, 2015 | 10:11 AM
roundheadlightsonly
also checked vacuum and electrical connections to I.R.C.M. cleaned all carbon deposit from intakes . just pulled plugs back out all look fine.
Old Dec 18, 2015 | 03:54 PM
pdqford's Avatar
pdqford
Fuel pump also replaced?
Try taping a fuel pressure gauge to the wind shield and go for a test drive.
Old Dec 19, 2015 | 03:19 AM
roundheadlightsonly
will try fuel gauge. I think it should idle@65p.s.i. and 70 p.s.I. under load . where is the best place to tap in.. fuel rail connector?
Old Dec 20, 2015 | 02:58 AM
roundheadlightsonly
can anyone help me with proper fuel pressures? idle and under load. 97 4.2 auto 4x4
Old Dec 20, 2015 | 04:22 PM
pdqford's Avatar
pdqford
Running - 28-45 psi.
KOEO - 35-45 psi.
per shop manual.
TallTexan
Apr 6, 2018 08:24 PM
danny3965
1997 - 2003 F150
Apr 27, 2012 01:04 PM
2jhanna
1997 - 2003 F150
Jan 21, 2009 03:24 PM
msm7c
1997 - 2003 F150
May 7, 2005 06:11 AM
Ricebird
1997 - 2003 F150
Apr 25, 2003 09:40 AM
