alternative transmissions
Old Dec 16, 2015 | 12:19 PM
Bird-Dog 250's Avatar
Bird-Dog 250
With trucks is there a transmission that can be used instead of an E4OD. Building a hot rod one can use a 747 trans coupled to a Chevy or a Turbo 400 to a Ford with adapter plates. How about OBS trucks?
Old Dec 16, 2015 | 03:41 PM
Mudsport96's Avatar
Mudsport96
I would assume if you are using adapter plates any combo can be used, but would probably have to run a C6 or manual trans ecm.
Old Dec 16, 2015 | 03:48 PM
Bird-Dog 250
It probably is a bad idea for a 250HD. It would be interesting to put an Allison behind a 7.3.
Old Dec 16, 2015 | 04:06 PM
Bird-Dog 250
I wrote before I did some searching... Here's what I found at Dieselstop.com
The Allison will bolt up if you switch to the Commercial 7.3 Bell Housing like the MD 7.3s used. You can find them used for around $300 used.
You would need a GM transfer case (use the 261) as the spline count is different than the Ford.
You would need a 7 position gear selector.
You would need to adjust your driveline lengths.
You would need the TCM from an Allison that matched that tranny. TCM is the computer.
You would need to build a simple wiring harness and tie into a 12V source, the TPS, on/off brake light for unlocking the TC under hard stops, and ignition.
You would need the commercial flywheel and crank drive hub.
And the only hard part, you have to find someone who can reprogram the TCM to work w/ your motor. There is a dude in Indiana that does it and a guy in CA I think.
It is a MUCH better tranny than what we have and for around 3K you can build it up w/ a Suncoast kit and it would be bad.
Personally I'd have to have the 6 speed double OD version although you can convert the old 5 speeds to a 6 speed for about $1600.
Old Dec 16, 2015 | 09:32 PM
dixie460's Avatar
dixie460
What happens when the TCM chokes on a fault? Can you read that thing with a standard scanner or does it have to go thru another module first?
Just wondering out of curiosity. My current truck will be my last automatic truck. LOL.
Old Dec 17, 2015 | 05:21 AM
Bird-Dog 250
It all sounds great but some of the conversions cost upwards of $12,000. That's a bit out of reach for me. I like my truck but not that much.
I'm with you!!! Next truck will be a stick. Hmmm what does it take to change it over$
6lpowerstrokesrj
Sep 11, 2022 02:33 PM
woobiemonster
Feb 26, 2016 12:45 PM
Clifford74
Apr 6, 2014 01:54 AM
lite-rescue1233
Feb 3, 2011 04:15 PM
knapikmichael
17
Jul 12, 2010 10:05 AM
