Bad head gasket?
Old Dec 15, 2015 | 01:17 PM
mike_black's Avatar
mike_black
Bad head gasket?
My truck was running a little rough today upon startup.
Stopped at a gas station and routinely checked the oil to find a rusty liquid all the way up the dipstick, and then a milky white color in the oil at the bottom. (just changed the oil about 5 days ago and there was no coolant in it at all)
How to tell if this is a head gasket going bad or coolant leaking into the timing cover, I did notice a small puddle of coolant siting behind the waterpump.
-Can't see white smoke in the exhaust, but I will check later to see if any comes out upon cold-starting.
-Also the engine is not overheating like a typical bad head-gasket, it's actually not getting up to temperature at all (changed thermostat last month), or the sending unit is bad.
Old Dec 15, 2015 | 01:26 PM
ctubutis's Avatar
ctubutis
A leak-down test will answer a lot of questions....
Bzfoster
May 1, 2019 06:49 AM
Sabdiel Mendez
1997 - 2003 F150
Feb 16, 2018 11:45 PM
RunRed
May 16, 2006 08:13 PM
vulch
1983 - 2012 Ranger & B-Series
Nov 28, 2004 02:37 AM
